  • Replies 305
all paid for... time to spin some rollers :D
cranked boost up to 11, wow what a difference. slight misfire gonna be a problem on the dyno? coil packs are a bit worn :(
you running standard ecu marko?
Umm whats the gapping on your spark plugs marko
if they are at a standard gap then take them out and regap it to 0.8mm
that should solve the problem
Could be plugs, what gap you running and how old are they? NGK BCPR6ES are a good plug for the 25 and come pre gapped to .8
Best thing is they are only 26-30 bux a set.
Add another 10 to that then they start to boogie!!!!
standard ecu, standard coil packs, hybrid front mount, trust 3.5" cat back, in line boost controller @ 11psi on stock turbo, pod filter
ive taken the coil packs out yesterday and insulated them with good quality electrical tape, the plugs were 1.1 but ive re-gaped them to .8 and they're only about 3,000km old. Will be getting some insulating silicone over the weekend for the coils as well as new .8mm plugs + get the afm cleaned up.
hoping it will solve the issue. apart from that im looking in to a toshi remap or safc once i get the rest of the exhaust, injectors and fuel pump. cant be bothered with a whole new ecu as i'm not after much more power so don't really see the point in spending over 2k.
well i hope you get the car running sweet as marko for the dyno day
ahh well you got about a week to get it happening then mate
should see a decent power figure out of that
one would assume so Wayne Daniel only posted up yesterday there were a few spots left... and worst case scenario ill sell my spot on the day if someone missed out
AWD = $50
FWD, RWD = $40
call up Graham West Workshop and sort it out, or drive in, fill out the form and give em the $$.
668 Marion Rd
PARK HOLME
SA, 5043
(08) 8277 5688
and my misfire is sorted :(
Edited by tx3_90
yeah drop in on the day there are always things that keep people attending so there are always spots to buy on the day and as i said earlier worst case scenario ill sell my spot
hmmmmmmmmmm ill decide on the day........
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
    • I could see someone trying this to save money on oil changes.
