  • Replies 305
for some stupid reason mine only made 66kw. Even last year made 85kw with a shocking missfire. No one new what was going on. Even ran in rwd for one and still the same. Strange.
Its all that heavy chrome on your dished rims and the wide track that makes it difficult for your engine to spin :blink:.
my run from yesterday.
http://i581.photobucket.com/albums/ss255/t...v/dyno14309.jpg
previous dyno sheet. before some small mods but with out the 18s and semis
http://i581.photobucket.com/albums/ss255/t...v/dyno10109.jpg
Nice one, who tuned your car if ya dont mind me asking.
my dyno sheet,
misfire killed it :P but the car is almost stock so not complaining.
got a bunch of parts coming in the next month, hoping to push it a bit past 200 :P
videos are uploading atm...
Edited by tx3_90
buy the guys at Aussie Dyno tune on port road. but there wasnt much in depth tuneing as sutch because its just running the standard ecu. purely adjusting boost and fuel presure.
videos now up in the same folder (missing krishy's and mine as they were over the mb limit, gonna be up later)
http://s2.photobucket.com/albums/y33/kfsRu...Day%2014-03-09/
enjoy :P
Edited by tx3_90
Gav those semi-slicks definitely held you back.
Just speak to Matt (whatsisname) about the difference it makes without them.
From what I saw, I'm guessing your car would've cracked the 200 mark.......better luck next time bud.
Good to catch up again with you, Louisa and Rachel.
well organised PGA guys, well done on another great day!!
dont know what happened to my car, still has me miffed a little as to what caused such a drastic lean out, I think the pressure hose blew of the fpr as his readout was only showing 15 psi but my ebc was reading much higher!
havn't confirmed my wideband sensor is stuffed yet but will be getting a new one asap, I think it's reading opposite to what the afr actually is, handy!, I may have cooked it running it in the dump directly in the line of fire!! anyway tuner error, lucky Lee's was fine.
Edited by 180or200
yea 200 was what i was aiming for. but im definitly gona try again with the standard wheels and see what hapens.
matt have u had a similar experiance?
i saw yor car shred those micky thompsons. i dont realy under stand why they are so good on the street/track but let you down on the dyno.
Edited by Turbo_Gav
much kudos to the guys from PGA, and also the GW guys too
sorry bout soooo much smoke LOL
http://s2.photobucket.com/albums/y33/kfsRu...nt=DSCF0043.flv
quite happy with my 63kw (but 275nm of torque). its a stock turbo diesel
Definately seems strange Adrian thats for sure. I cant believe your beast still managed 340rwkw in a far from optimum tune should be awsome once you sort the little gremlins.
Brett was so impressed with my tune that he asked me who done it, i just said some bloke out there lol.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
