Pga-sa Interclub Dyno Day #3 - 14th March 2009!
car_fanatica
 Share
  • Replies 305
my run from yesterday.
http://i581.photobucket.com/albums/ss255/t...v/dyno14309.jpg
previous dyno sheet. before some small mods but with out the 18s and semis
http://i581.photobucket.com/albums/ss255/t...v/dyno10109.jpg
Nice one, who tuned your car if ya dont mind me asking.
my dyno sheet,
misfire killed it :P but the car is almost stock so not complaining.
got a bunch of parts coming in the next month, hoping to push it a bit past 200 :P
videos are uploading atm...
Edited by tx3_90
buy the guys at Aussie Dyno tune on port road. but there wasnt much in depth tuneing as sutch because its just running the standard ecu. purely adjusting boost and fuel presure.
Gav those semi-slicks definitely held you back.
Just speak to Matt (whatsisname) about the difference it makes without them.
From what I saw, I'm guessing your car would've cracked the 200 mark.......better luck next time bud.
Good to catch up again with you, Louisa and Rachel.
well organised PGA guys, well done on another great day!!
dont know what happened to my car, still has me miffed a little as to what caused such a drastic lean out, I think the pressure hose blew of the fpr as his readout was only showing 15 psi but my ebc was reading much higher!
havn't confirmed my wideband sensor is stuffed yet but will be getting a new one asap, I think it's reading opposite to what the afr actually is, handy!, I may have cooked it running it in the dump directly in the line of fire!! anyway tuner error, lucky Lee's was fine.
Edited by 180or200
yea 200 was what i was aiming for. but im definitly gona try again with the standard wheels and see what hapens.
matt have u had a similar experiance?
i saw yor car shred those micky thompsons. i dont realy under stand why they are so good on the street/track but let you down on the dyno.
Edited by Turbo_Gav
Definately seems strange Adrian thats for sure. I cant believe your beast still managed 340rwkw in a far from optimum tune should be awsome once you sort the little gremlins.
Brett was so impressed with my tune that he asked me who done it, i just said some bloke out there lol.
 Share
    • Wow its been a while since Ive signed in for sure.  Time gets away... Good question. So much was different between the two designs.  The RB315 was a test to see if I could do it.  Limitations were for the most part due to local machining capability.  Tolerances were an issue.  The 3.15 used a single OD dry sleeve, and was almost the same as a kakimoto spacer plate engine, except I used a plate design similar to the OS Giken plate.  I did not make the top flanges thick enough either.  I can't be sure if it was machining tolerances, or thermal distortion of the sleeves, but the engine did produce quite a bit of blow by.  The modified 87mm RB30 crank was also an issue, and was no where near as nicely balanced as the forged 90mm crank in the 3.4. The 34 was a next level build.  The sleeves were stepped for max thickness, and were a semi-wet design breaking though into coolant completely in the block.  Minimum thickness was 3.75mm and max was 5mm with the 90mm bore, and the new spacer plate also fully supported the tops of the sleeves closed deck style.  This combined with far superior CNC machining, and a cylinder hone finish that the machinist does on 3000hp pro stock cars resulted in no noticeable blow by at all.   In the end the 3.15 was removed to swap in the 3.4.  I discovered the modified RB30 crank had partially sheared the woodruff key on the balancer.  That was all that was wrong with it, but it did make the engine a paperweight at that stage. $1100 to make another crank for an engine with blow by issues was not worth it, considering I'd started playing with all Nitto forged internals instead. I hope you found this interesting.   Cheers, Ian
    • All their parts, when order directly off them are made to order. So you're able to customise fitment of things or delete things. E.g. I asked for no throttle cable bracket, no IACV port, etc. on my plenum. In hindsight, I should have asked for an IAT port/fitting welded on, hindsight no. Should have bought a M2 or 3 lol.
    • 25de in c33 a31 is different to r32/r33 s1 which is different to r33 s2 & r34 so you can vaguely do whatever man.
    • That's the pink sticker type, you haven't said what car so no idea if it's correct, 25de or det is the same in the same model.
