Sorry bud.
Try this site;
http://www.fastestlaps.com/car47d9a014adba0.html
I do think that is conservative... They are "official figures"
I do have to say though, when wheels compared the then-new HSV GTS with the NUR R34, the 34 put out over 220awkw on a 36 degree day, while the 300kw GTS put out around 210rwkw on that day. (If memory serves me).
^^ Yeah your pretty much right on that one iamhe77. I got that issue of Wheels and they said something about that.
R34 GTR Nur = N1 Block, upgraded internals and turbos.
They run 1.1 Bar Boost stock.
Japan was still under the "Gentelmens" Agreement that no car would excced over 206 kW.
The site what iamhe77 is something to go by but not really a reliable source IMO because I preffer the stats to be published in a magazine, for example.
Tim GTR has a Nur but his is tuned to 303 awkW.
Or ask Iron Chief, he has a R34 GTR N1, which is what the Nur is based on.
he he the infamous article huh? from memory the N1 in that article put down similar times to a 996 Turbo. 206kW: yeah right nissan :thumbsup:
My guess is the nur's made similar power to the ordinary N1's seeing as they had the same drivetrain.
They have different rubos and different engine block, but I can't find anywhere that says it has more power than the other GTRs? Do they?
different engine block, but same bore and stroke. Just reinforced..
and the pistons and rods are balanced. (not same as blue printing, really
just the factory putting them into bins according to weight then pulling six
from the same bin).
I think a stock r34 will tune with a power fc to a bit less than a stock nur
with the same basic set of mods (intake and exhaust).
No idea what stock boost nur was set to, or whether or not it had the
same boost restrictor installed.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
