Not 100% sure.....Stock dumps, SS Y piece,then 3.5" SS system through a brand new hi-flow cat, then to the rear canon. Not sure if it has a hotdog in there, but I don't think so. It's not toooo noisy, but clearly if I had CHiPs on my tail I might be sweating it a bit.....
OK, here we go.
The 'small' Garrett turbos (7s)
Power FC
Tomei 700cc injectors
Adjustable cam wheels
Forged pistons
Full bottom end re-build
Oil cooler
Large capacity aluminium radiator
Approx. 305 RWKW and a shitload of torque.
OK, here we go.
Power FC
Forged pistons
Oil cooler
Now thats what im talking about; that is my future mod list appart from the oil cooler and radiator.
305rwkw; about 280awkw? Not too bad at all.
Thanks mate. If you're tracking it, keeping engine temps down is vital or your mega $$ rebuild will come around again sooner than you want.
Just a street car man; my oil temps right now never go over 88degrees. I have it tuned ATM with stock turbines to 255awkw and really like the response so ill definitely be going -7 or -ss when the yen comes back up.
How would you, taking the first drive till now rate the -7's in terms of standard response? ive read alot on this site about the -7's but prefer to hear from actual owners.
Torque at low rpm is what im interested in and removal of that top end post 7000rpm restriction from stockers.
how high do your oil temps get on the track anyways
-Johnny
Really hard to say about the difference with the tubos as it was a couple of years ago when they went on. Stuffed if I can remember. When they went on the car went from 190RWKW to 260 RWKW so it all felt pretty damn good! I don't recall feeling any additional lag when they went on. Never driven anything else so can't comment on the 5s. I would like more top end in mine, but I might already have that, but with so much mid-range torque it might be masking what is actually a good top end perfomance. Just want that last mad rush for the limiter. Might also be the tune. Tuner has said it's tuned for torque as it makes the car quicker (in real world situations) in almost all but flat stick applications (which never happen as often as you think).
I've heard journos challenging each other to keep the trottle pinned for more than 15 seconds in a Veyron as it is apparently almost impossible unless you've got a runway at your disposal. Same, but to less extent, might apply to the old GTR. Wide open for long periods = not very often.
Oh yeah, oil temp about 100-110 on the track.
Thanks for the impression man, im sure the top end is better than stock though. Maybe some cams may open the topend without sacrificing the mid; i know that in my old s15 some stage 1 HKS cams were fantastic.
15 second in a veyron would be like about 200mph, i think its 0-300 in 14seconds so if your already doing 60kph and flat foot for 15seconds you would be going 350kph and thats not exactly comforting lolz.
Only certain sections of the autobahn would be possible!!!
100-110 would freak me out on the road, when i get the new turbos if my temps go anymore than 95degrees then ill definitely grab an oil cooler.
Amazing looking car you have though, the r32 gtr is just sooooo aggresive like twoogle and a few members on this site.
100 to 110 depending on the oil grade [i.e 10 w 40] should still be pretty safe. mine went up to 113 degrees on a track day with 35 degree heat. Thats about the max i think you would ever want to run. if it was always that warm [air temp] i would def go for an oil cooler. will be interesting to find out what oil temp will be on say a 23 degree day. A friends 997 on the day ran up to 130 degree's. no problems- yet anyway. If you get a cooler, get a thermostat. Oil under 75-80 wont do you any favours. wanna know more have a look on gtr.co.uk. look for a thread by oilman. full of really good info
My old 32 looked identical to this one. Always flamed 3rd to 4th. and night time mountain runs were brilliant, it always lit up the cliff face!!
'a mountain pass lighting up the cliff faces with flames!' seems like a scene from fast n furious 4 :P
130degrees in a porsche.....wow! must be some heavy grade factory stuff
Does anyone know the benefits of the boxer engines when it comes to lubrication????? :) (lateral g'z and temp)
Yeah well there was no CGI Johnny, let me assure you!! :P
The porka's was running very warm, the fans belted out hot air by the front wheels for about 5 minutes. There must be two radiators/thermo fans in those things up front.. Not sure the advantages of the boxer setup though...
Edited by Duncan1
    • I have engineer in my job title One of or motto's though is "we make and we break"
    • This is actually 2 whole different trains of thought that need to be addressed separately. No, as Matt says above, "Engineer" is not a directly protected title. A lot of guys who just do mechanical design via CAD, with or without even some sort of associate diploma in engineering, often have the job title of "Design Engineer". A train driver can probably still describe themselves as an engineer. But, to usefully get employment with anyone as a proper engineer, you're going to have to have at least the necessary and relevant degree qualification. You're not going to get a job as an electrical engineer if you have a chem eng degree, unless you can demonstrate x number of years of working in that capacity, sufficient knowledge, etc. Having the degree is at least in indication that you've seen the relevant text books, even if you haven't read them (like pretty much the last 10 years of graduates!). To be a self employed engineer.....you could get away with quite a lot pretending that you're suitably qualified, without actually being a proper engineer. But, you will find yourself unable to work for a large section of the client space because a lot demand CVs and capability statements when considering contracting for any engineering work these days. Insurances too. If you're not a proper engineer, it will be much harder to obtain proper PI insurance. Insurance companies have gotten hip to that. The "Professional Engineer" thing is a thing in Australia. If you have the right qualifications and experience you can apply to the relevant engineering top level body (mostly Engineers Australia, the less said about whom, the better), to be assessed and approved as a Chartered Professional Engineer, CPE. There are high bars to get over and a requirement for CPD to maintain it. The RPEQ thing is similar-ish, in that you have to demonstrate and maintain, but the bars are a little lower. It is required to be RPEQ in order to sign off as an engineer on any engineering design in Queensland. The other states haven't fully followed suit yet. There's "engineering" and there's "engineering". Being an engineer that signs off on timber (or even steel) frames for housing projects, council creek crossing bridges, etc, is a flavour of civil engineering that barely warrants the name, description and degree. That would be soul crushing work anyway. Being an automotive engineer working in the space where you have to sign off on modifications to cars and trucks would also be similarly soul crushing. At least partly because of the level of clientelle, their expecations, depths of bank balance, etc. And that brings us to your second question. No, we do not have professional engineers "do vehicle inspections". Well, not the regular roadworthies, etc etc. That's done by mechanics. There might be some vehicle standards engineers at the various state govco inspection stations where cars go to get defects cleared and so on, but that's because they (the cars) are there specifically for defect inspection and clearance and so the stakes are a little higher than on an annual lights and brakes working check. But, if you modify a vehicle in Australia, you have to get it engineered. A suitably qualified (and effectively licensed, which I will get back to) automotive engineer will have to go over the application, advise on what would be required to make the mods legal, supervise some parts of the work, inspect and test the results, and sign off. The "licensed" aspect comes from there being a list of approved engineers to do these things in each state. They have to jump through hoops set up by the govco vehicle standards divisions that mean only the suitably qualified can offer to and approve such mods.
    • It's got a problem Prank... It looks like both washer spray caps have fallen off this car... 😛
    • Meh, it's only got to last another 10 years or so until you'll be forbidden to drive it. Keep it dry and forget about it.
    • The title of Engineer is not protected. However different states have different rules about what an Engineer requires to operate. Engineering for a motor vehicle modification is very different to engineering for a bridge, electronics, etc, including what that engineer needs as certifications.   In Canberra, "Engineer" is the loosest category with basically nothing stopping you calling yourself and engineer and designing a bridge or building. From what I've reviewed, QLD has the strictest requirements through RPEIQ.
