Hey need some help today my speedo just decided to stop working and then the power steering stops working about 5 min into driving, i think the speedo has something to do with the power steering not working (not adjusting pump to speed). my question is how does the speedo work is it an electronic sender or is there a cable and if so where is it. Any help is greatly appreciated. Thanx
https://www.sau.com.au/forums/topic/248690-power-steering-and-speedo-dont-work/
ive got a 96 r33 too.. "sometimes" the speedo decides to stop working too.. i just knock on the top of dash while im driving and it pops up agian working...
Tried that, i bashed the shit out of it thought the needle might be sticky but there is definitely some other problem.
Do you have any aftermarket units connected to the ECU, such as Apexi RSM, AVCR, SAFC?
Well if you do, check around the ecu if any wires are grounding itself against the chasis. Well this happened to me causing the power steering to go heavy on certain corners.
Nah the ecu hasnt been touched its pretty much stock
Most probably your speedo cable has snapped, which thinks your car isnt moving therefore power steering not working. the cable is located behind your speedo cluster which then feeds through the firewall into the gearbox. new 1 only cost arnd $100 from nissan
I have been researching it extensively and the r33 has electronic speed sensor as opposed to the r32s cable driven speedo, seems that i am lookin at a problem with the speed sensor or dash cluster. Anyone have a spare dash they wanna let me borrow? I will replace the sensor and go form there.
Hmmm maybe you could use the R33 Service Manual to help diagnose the problem or to test the speed sensor. I doubt the instrument cluster would die out so fast or at all....
I got the speed sensor out doesnt physically look broken the two wires coming out of it are open circuit, unsure if that is the way they are supposed to be. I would guess it is just a permanent magnet volage generator and as the speed increases the voltage does too. If so then the wires should be connected. Anyway im gonna replace it when i find another one (so far impossible) and see if that fixes it.
Your rear hicas has been removed. The front still works off the hicas system. Light steering at low speeds heavy steering at high speeds. Default must be heavy(when you speedo stops working).
Edited by RR 84 WA
Didnt really know there was hicas at the front just thought that the power steering was adjusted according to speed. May be a good thing its default is heavy steering, especially if you are travelling quickly, dont want a slight movement of the wheel turning into a 45 degree turn.
  • 2 months later...
Hey guys i have recently had the same problem in my r32. Thought i would search first and found this thread.
My speedo stopped working first, then 30mins later steering went heavy. Power fc isnt getting reading either. Guess thats cos it reads it from the speedo cable which leads me to think that the cables the problem. Also i have an rb25det gearbox. Do the r33's have a sensor in the gearbox that converts in to electrical signal or is it a cable to the dash like r32.
Also i spun the gear in the back of the dash with my fingers and the power fc picked up 20km/h but the stock speedo guage didnt so would this mean that the cable is snapped somewhere or that there is a problem with the gearing inside my dash cluster??
Power steering is now intermittant too. 1 min its working fine then the next, it goes heavy.
Hope that all makes sense. Any help would be greatly appreciated.
Cheers
Edited by Bennett
Cheers
33 uses an electronic sender, however you would have a mech. sender in the 33 box to make your dash work.
i'm not sure how the cable setup works (i'm just about to put a mech sender in the 25det box in my 31) but can you spin the cable at the dash end? if so i'd imagine the cable has snapped, if not then your dash would likely be the issue.
Just worked it out after a bit of searching. I didnt know why the little spastic thing wasnt spinning but the cable was. Has a slit down the side and so doesnt grip properly. Also wasnt aware that they were supposed to be 1 piece lol. So super glue it back on for now otherwise have to pay 100 for new one and install it.
Good luck with the conversion.
    • The exhaust gases are at their highest temperature as they leave the exhaust port and enter the manifold. They cool as they flow through the manifold because they transfer heat to the manifold and the manifold loses heat to the surrounding environment. Thus, inevitably, the exhaust gases are cooler as they enter the turbo compared to when they entered the exhaust manifold. So, yes, the exhaust manifold can easily get as hot as the turbine housing. Having said that, you will generally see the highest temperatures where the exhaust gases have to slow down or they are concentrated into one area - which is usually the collector on the manifold and in the turbine housing, because the gases slam into the metal at those places, increasing the convective heat transfer coefficient and transferring even more heat to the metal than they might just flowing past elsewhere. Exhaust manifold heat shields are a good idea - certainly for the stock manifold they are there from the factory. People seldom have anything like that on a tubular manifold because they are hard to achieve. Some might wrap a tube manifold with fibreglass tape - but this has a reputation of leading to cracked welds. The best case is generally to put ceramic coating onto the manifold to prevent it getting as hot (internal coating) and radiating/convecting heat into the bay (external coating). All the real heat from a turbo comes from the exhaust side. The gases entering are at ~800-900°C and the steel/iron gets nearly that hot. The compressor side is only going to heat the charge air up to <<200°C (typically not much more than 100°C). So that's nothing, by comparison. The compressor is not a significant source of engine bay heat.
    • Late to the party, specifically joined this forum as I just bought one of these and this thread has been a gold mine of info. If the OP is still around, mind if I ask what gas you been putting in yours? Mine has a Japanese sticker in the cap saying premium but it seems to get way worse mileage on premium (95) than 91. I always thought it was meant to be the other way round🤷 I do think Nissans claimed "6l/100km" is a bit fantastical 😂
    • Does exhaust manifold get hot as turno exhuast side? I have a turbo cover to managr heat in the engine bay but  nothing is covering the exhaust manifold before turbo   i know as turbo does compress air, the temp does go up however does that mean exhaust manifold would be as hot?
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
    • Yeah, well I was probably way underguessing the $300 figure anyway. Just multiplied a "normal" by 4 for the purposes of pointing out it's not cheap, particularly if it has to be repeated.
