Got to do a 5,000K service this coming week. Thought Id pull one of the sparkies out to check its condition and part number ect.
In their are Champion RC10YX4 Gold Sereis (gapped to .8mm) and according to the previous owner they were put in at 98,000 and this will be a 115,000 service.
Do they need to be changed yet? The car is runing ok just wondering if I should chuck some freshies in? If i need to get new ones how do I gap them to .8mm or do i purchase them allready at .8mm
This is how the one i pulled out looked :
Cheers,
Chris
https://www.sau.com.au/forums/topic/248698-spark-plug-question/
My old man has had problems with Champion plugs previously (admittedly, it was many years ago) so we've never trusted them. NGK, as Tangles mentioned, are the way to go. If you do intend to keep those ones (they look fine apart from some gunk on the tip of the electrode), just give them a clean and make sure the gap is still at 0.8mm.
Copper plugs apparently don't last as long as Iridiums or Platinums, but they are a better conductor of electricity, so provide better spark.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
