*grabs pitchfork*
In all seriousness im looking at moving to malaysia. Went there for a holiday, mountain passes, cops who can be paid off, cheap cost of living, win?
bad weather, unrealistic tax on car prices low wages...lose?
  • Replies 61
weather isnt that bad, low interest rates, low tax rates, wages are fine as long as you arent a bar attendant i have a mate whos a lawyer over there bringing in the money, and another mate of mine owns a car shop also bringing in the money. Not to mention incredibly low housing prices.
Edited by Greg89
yea i guess if you dont mind the weather and you have a good proffession it can be okay. Im only saying that from a personal point of view because i lived there and i prefer australia. Sorry mods as this is totally off topic.
I didnt see any leaks? But then again I didnt really have a close look.
Told you the HIDs were illegal! lol. BOV I was expecting. I was pretty sure the exhaust was still too low. The window washers all worked!! WTF??
I dont see how your tint was too dark, and I thought you fixed your brake lights?
Glad they didnt notice the lack of AFM, but they seemed to pick up that we'd thrown my cat on :P
Oh well, give Chris's work a call first thing tomorrow morning and they'll try and book you in.
looks like your keeping my noncat for a while rhys... and they were mad about the missing bolts on the cat / exhaust
Your not going to hear me complaining! Haha.
And yeah, I though they might have. Better do a better job with that next time. Forgetting the gaskets wasnt the best idea :P
lol you got reemed!
Some quick tips:
1. get a high pressure washer and blast your car rather thoroughly before going to the pits
2. shouldn't get done for stupid things like brake lights etc, check all fuses and globes before going
Basically they are going to check EVERY stupid little thing (lights, washers, windows go up/down etc etc) before they move on to the big stuff.
What pits did you go to?
lol battery to be vented? I think its personal when the washer squirts lol..That radius rod issue, are the rods really damaged or it just looked oily? I've been trhough the pit with the same problem, because apparently the oil will somehow react with the bush and eventually damage it. but the pit ppl does not care if the bush is still ok or not, once they find oil, they'll tick as a defect. all you have to do is just wash it down clean.
The battery vented problem is that he obviously has a boot mounted battery (in a box) and the box hasn't got a snorkel (bit of tube going from the top of box thru the floor of the boot to the outside of the car).
correct. the radias rods are actually damaged, they are bent in a little at the bottom, easily fixed i think, just get a hammer and a screwdriver and whack them out. I did replaced all the globes previously but yeah it must be a fuse. there is no oil leaks either its just road glimes building up that i didn't get the chance to remove.
just take off the vaccum line on the BOV and block it, that is only to get over the pits, i just got yellowed today for POD FILTERS and my GT wing hehe, only had my car back for a week and yellowed already, i havnt even bedded my clutch in yet, i hope the inspector doesnt floor it when he checks it out
Tell the guy to take it easy because of that, If he f**ks your car then they should be liable to fix it. They aren't gods who are above the law.
permits are not required for pod filters they only have to be secure
pm me your email addy and i can email u a government document stating permits are not required for them
    • FD RX7 I would probably marry if legal R32 GTR is toughest NSX looks like it's made from leftover Prelude and Accord bits
    • When going to a suspension shop should I send them the default nissan settings or just let them do their own thing? I ask this because I have aftermarket rear camber arms (front end is basically stock after I change to those nismo bushes)
    • Ok sounds good, thanks for your help. Hopefully if I end up changing it to the nismo bushes I don't get that veering issue. I don't think there's a point in lubing up these bushes again. Weird that it it makes just as much noise with all the grease inside it versus without grease prior to removal. Bizarre.
    • Yeah, you don't need camber bushes on stock arms to make a car drive straight unless it's got another problem. F'rigsample, slide the thing into a kerb, bend the front subframe mounts a little....subframe is now twisted, shifted or otherwise in the wrong spot...and you need to do funky stuff with the wheel alignment to get it to drive straight. Maybe a little more caster on one side, or a little more camber. FWIW, I can have my camber off side to side by a half a degree or more, and either way, so more one side, or more on the other, and the car doesn't really want to pull to one side. It will definitely ride road camber differently, and want to track uphill (ie, towards the centreline when on the LHS of a normal crowned piece of road, like it should) or want to roll downhill (which it really shouldn't). But on fairly flat road surfaces, like the middle of a 3 or 4 lane motorway, a half a degree either way doesn't make a lot of difference. I sometimes do quite a few miles with my wheel alignment messed up, because I don't always get a chance to set it right again after a serious dismantling, before I have to drive it to work again. Like, a whole week's worth of daily shuffle.
    • To clarify, I meant nismo bushes, not control arms (don't even think that's a thing for my car). So the suspension specialist said, if I buy those nismo bushes which are perfectly centered it will cause my car to veer in one direction. Whereas he said the current offset bushes that I have were put in on purpose to fix that issue. This will be my third wheel alignment if I put these bushes in lol. My chassis is straight, all my rails are clean.
