I was driving home yesterday and all of a sudden the car stopped accelerating, then it would kick in again and drop out... Best thing i can relate it to is when you're almost out of petrol, only it was worse than that. Like when you drop the clutch taking off and it bunny hops up the road.
It wasn't happening at any particular revs, and it was happening both on and off boost. It got so bad that i had to pull over. I turned the engine off and after about 5 minutes i started driving again and it drove fine for around 2 minutes, then it started again. Had to keep stopping and starting the whole way home.
Not sure what the issue is, its got over half a tank of fuel and it's been fine up until now, and i haven't made any recent changes to the car.
It's a Series 2 R33, power FC, running about 13psi. I've done some searching and people with similar problems have mentioned the coilpacks being an issue, mine are still the stock units so could this be a possibility?
Thanks in advance for any help!
https://www.sau.com.au/forums/topic/248739-power-cutting-in-out/
Check spark plugs, coil packs, AFM's and then the alternator/battery?
My mates car had a issue where it was running like it was nearly out of petrol, everything was going weird... turned out the alternator was stuffed and wasn't powering the fuel injectors correctly.
I have had issues lately with the headlights dimming when clutching on gear changes, and the battery went flat after not being driven for 3 days so i took it to an auto electrician but they said the alternator was fine and the battery wasn't charging properly (Oddysee dry cell, just over 18 months old). I havent replaced it yet but it's been doing that for about 1-2 months and besides the above two issues, it's been fine (and that will be replaced soon anyway). Could that be the issue? It seems weird that it would drive fine after turning off the engine for 5 minutes though if that was the case?
Thanks for the reply too mate.
Edited by r33skylinegtst
its happening with my 32 aswell it doesn't happen all the time but its getting more frequent now. it'll cut out for like 1-2 seconds and then jump back on. don't think it would be my afm...can someone tell me how to check my spark plugs and coil packs as i'm a noob at this stuff lol?
Jake, I found these tutorials on removing and repairing coil packs, i'm going to try this out when i have some time maybe you'll find them helpful too, seems they apply to the Series 2 RB25, but it may still be similar?
http://www.skylinesaustralia.com/forums/RB...ark-t42819.html
http://www.skylinesaustralia.com/forums/Fi...em-t119403.html
Having the same problems as u guys have been now for 3 months i have treid various things AFM, Battery, Alternator, Ecu... i actually think its more the AFM and wiring and ecu as i recently deiscovered AFM wiring breaks and when the car has been driven for a while it start to play about so thinking ECU if u guys ever get stuck anywhere just do what i do un plug the air flow meter will run on safe mode which means ur car will not rev over 2500RPM but it will go fine and wont jump around on u unless u go over 2200 to 2500rpm dont get alarmed if ur car cuts out when u first unplug the AFM or pulse's when ur AFM is un plugged its just the engine running on safe mode
Edited by Jay B
Not sure that my problem lies with the wiring, i've checked as much of it as i can get to and it looks to be fine. I'm thinking it's spark plug/coil pack related. I've removed the coils and have a set of splitfires in the mail from Sliding Performance, plus replacing the spark plugs with NGK PFR6G's, which are pre-gapped at 0.8mm. Will install them once the coils arrive and let you know if this solved my problem.
I had this once when running my old setup, it was very annoying as the car would cut out quite violently, a few times it did it I had to crank the car for a few minutes before it would start. Since you have a PFC I'd do an ETC > SENSOR SW CHECK to start with and then follow up with pulling the airflow meter off and cleaning it. In my case I had a dirty air flow meter, but it didnt register as a problem after doing an ECU diagnostic... Regardless the problem didnt come back.
ey man changed over my fuel filter and it was full of a rust substance...changed it over with a new ryco one and its all good now. if that doesn't fix it try the afm and spark section.
Yep, bolted it all back together last night and took it for a drive this morning, the issue seems to have cleared and maybe it's just me, but feels like it's running much smoother (but that could just be because i've been driving a sluggish '85 Patrol all week)
Thanks to the above posters who gave me their input, much appreciated!
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
