Item: OS Giken 5 Speed
Price: $4800
To Fit: (What car) R32/33/34 GTR Has mounts on bell housing for clutch slave both directions.
Comments: Used in good condition!
Once again someone is going to call on dirt garages cost list
DiRTgarage's thread for reference
For those who are not aware of what it costs to build these boxes ill post the following...
OS giken kit $4000
Nissan update parts $1300
2nd hand GTR gearbox $1000+
stripdown and assembly $700
Will combine Hks clutch for good price if you like.. Link to clutch!
Edited by Angus Smart
https://www.sau.com.au/forums/topic/248745-os-giken-gtr-gearset-r32-r33-r34/
Great kit, just put one in my 32R. Price on the gear set with h/d input shaft alone is now almost 5K without delivery. Andrew helped out on a GB I was on and he is a reliable trader.
Hey Andrew,
How many kms on the box? and does it have the strengthened input shaft?
Cheers,
J
Johno, if its a 5 speed kit it comes with the input shaft. I can arrange to have the box overhauled (id recommend it) in Sydney at Award Diff and gearbox if you like. These things are almost indestructable if you properly maintain them.
Hey, if i was to say the km's i would be telling lies, i would say not a great deal but i am no gearbox expert!
as for the imput i would now say it has a os one as its didnt look like standard nissan gear on the end as you can see in the photo, the left top gear connected to the imput :)
i was going to actually ask you Paul, where to take it. but now i know! :D
what do they usually charge to overhaul one of these if everything checks out ok?
I forgot to include as i have been asked a few times...
This is a full gearbox!! transfer case and all! ready to bolt on or after an inspection as suggested
  • 4 weeks later...
    • The jack pad placement always had me scratching my head. I only have a small section to work with on both the E90 and E70 (and insert new project car here ) and I could see lining it up to be a bit of a bugger. For me, the E90 is just too low and needs small ramps and then the front centre jack point is a bit tricky to line up (it's half way down the subframe and about the size of a tennis ball, its really hard to see unless your head is on the ground), so I definitely like the idea of not having to do a multi-stage jack and just sliding these bad boys in under the sides. There's only one small point at each corner, so I can't jack AND add a stand on the same corner. Or, maybe I can and I'm too nervous to try. 😟
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
