I dont know if they are even available?
Correct me if im wrong but didnt the r32 gtr not have side indicators as standard and they were only put in during compliance? This would explain why you cant find any.
Thats exactly what im looking for. Where abouts did you get them from and how much where they? Do you have the side indicators for that too? Ive been looking around the streets and the clear indicators on the new corollas look exactly the same size but i havent looked into it too far, just checking it out at the lights. Do you know or anyone else know if they are the same size and same connection to the bulbs?
Wouldnt the side ones for the gtst fit the gtr as well. there could be that much different in the placing of the headlights and the fitment of the indicators. They would have too be the same wouldnt they?
i got em from japan cost me around $5-600 about 5 years ago.
the retail at $650 plus shipping.
GTSt ones do not fit GTRs, because of the wider guards the indicators are different shapes
  • 4 weeks later...
Is thread about the ones next to the headlights? Mine doesn't have side indicators. I need some front ones as my current orange ones are leaking and faded. It can't be $600...... Surely some china copies are available? If anyone is selling clear/smoked please PM me.. Thanks..
Car is a 1989 R32 GTS4 if that helps, cheers.
Edited by Ten Four
you can get stock ones that are half clear or you can get some china ones that are clear but end up yellow after the sun hits them LOL
try a wreckers for the half clear ones dunno about the full clear china ones
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
