Hi all , on my mind ATM so this was interesting to read even though it involved 740's and a PFC on an SR20 .
http://forums.freshalloy.com/showthread.php?t=164058
If this is true then the lag times of std 370's Nismo 555's and Nismo 740's should be 0.58 0.71 and 0.66 ms .
One claim is that the PFC correction should be +0.08 .
Also been asking around for fuel settings to temporarily run my RB25 with these 740's - so I cam get it home once the ported cammed head goes on , logical to fit the injectors while it's in bits .
Cheers A .
I have a set of 740s nismos yet to go in and I'm curious what the summary of the topic
is as well..
someone has evidence that the latency reported by the pfc faq and everywhere else is
actually better set to a different number?
The guts of it was that the original poster was changing from Deuchworks 740's to tomei 740's and couldn't get his SR20 to idle over 12:1 AFR .
One person suggests that the latency/lag time for Nismo/Tomei 740's is 0.66 ms and he thought the correction was +0.07 or +0.06 for the PFC . Says his buddy has tuned 10 SRs with Nis 740s and no probs .
Another person suggests 555s are 0.71 and 740s 0.66 , std 370s are 0.58 so correction is 0.08 .
At the end the original poster removes his 740 Tomeis and tries 740 Nismos and they work fine .
You don't find out what the problem with the Tomeis is but I suspect that their were two versions of the 740 available in the US fro Zeds . I seem to remember reading ages ago that some screwy engine needed possibly peak and hold instead of saturated injectors so the problem could have been an electrical one .
My 740 Nismos came in boxes with SR RB VG on the label so should be the right ones .
Cheers A .
Edited by discopotato03
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
