  • Replies 47
Posted Images
The only real benefit with stainless steel is it's resistance to Corrosion meaning it will last longer and it's stronger....Flow characteristics would be very simular, if not exactly the same as an identical mild steel system.
Edited by Ryanrb25
its in the way the ceramic inner to the cat has been made will flow more than a normal cat that is all nothing special in the steel only that it ISN'T Chinese its Aussie blue steel and or sometimes from NZ
Looks the goods!! Beleive he did some work for Simon as well and that was a great sounding exhuast!
2x2.5 inch pipes is going to flow more then 1x 3inch?? Or so you'd think (5inches of pipe compared to 3 inches makes a big difference)
Personally i'd rather keep the cat and loose a little bit of performance and not cop the massive fine for not running a cat but thats just my opinion
Not quite - area = pi*r^2, so:
3" pipe = 4,560mm2
2x2.25" = 5,130mm2
2x2.5" = 6,333mm2
5" pipe = 12,667mm2
so as you can see, 2x2.5 is definately not as much area (flow) as a 5" pipe by a long shot
^Not necessarily. There has been a fair bit of research (well particularly for V8s) and I think the results concluded there was VERY little difference between twin pipes and singles, and if anything a single was maybe 1-2% better flow from memory.
This is due to the single having less swirling restriction from memory, however for now I can't find the evidence to backup my claims.....
    • Please do not connect it to your manifold. If you do, as GTS suggested please record the lot in 4K with good mics attached.   On the factory Skyline, there's a upside down pipe that allows it to breathe, looks like this
    • For me I'd need some serious justification for why it has blown out.  Have you questioned him on it?  To be honest if you didn't question him right from the get-go on the first invoice that was already way over the initial quote and then you've (presumably) then paid another $1375 on top of the first invoice, then you're pushing shit uphill to get a favourable result now... It was years ago I last got an engineer out but it was around $450-$550 per visit.  That was just to inspect each progress point he gave me for the project.  Is he just doing progress inspections or is he providing engineering diagrams, technical assistance, etc??  If he's not, he's a filthy rip off merchant.  If the $3100 is the final sign off then you need to cop it on the chin, pay it and move on.  If it's not, piss him off and get a new one.  Not many Jeeps I'd value at $10K full stop let alone just engineering fees on a written off, half actual value WOVR Jeep....
    • Oh, yes. If you connected it to the manifold your first drive would be very eventful. Very shit. Very interesting. Perhaps take a video if you feel the need to see. Terminating the breather at the top of the bellhousing is normal/stock. Some gearbox lubes (hello Redline Shockproof) like to foam up a bit and require the breather to be extended up higher, so you don't get spots of smurf jizz staining the floor under your car. Mine is thus right up behind the head. Make sure you fit a u-bend at the top so it points back downward so that dirt and schmutz has a harder time getting into it.
    • Cheers for the replies. So i don't connect it to the manifold I just run the hose high up on the firewall?
    • It doesn't really answer your question...but is the head unit full android or just android auto, are you happy with how quickly it boots and responds, and do you have a link?  If we can identify good Android alternatives it will really help people stuck with Japanese screens. Did it have a separate reverse camera input so you would replace the factory one, or are you just going without now...that would be a pretty big steps back. And finally, do you have a picture of the "wire" that you can't plug in? Most likely it is some sort of aerial that is not too important eg japanese traffic or am radio or something if you haven't noticed a functionality issue
