Hey,
I've been doing some searching on whether you can bolt up an rb20 head to an rb25 bottom end and havent found any topics on it.
My questions are:
* Does it bolt straight up?
* Is there any merit in doing this?
Any help would be appreciated.
Cheers.
https://www.sau.com.au/forums/topic/248866-rb25-bottom-end-with-rb-20-head/
You'll see a much better gain by bolting up the whole RB25.
What is said above is correct also, water galleries do not line up.
The RB20 head flows no where near as much as the RB25 head. So it would be a huge backward step to do to the RB25 bottom end.
Considering you can grab a cheap RB25DET and drop the whole thing in, and your old turbo setup etc will bolt to it (If you're using a stock turbo, use the RB25DET turbo!)
Hmm i guess i'll stick with the rb20 and get a new bottom end.
Thanks for your help guys!
Dropping another RB20 in, VS picking up an RB25... Will be a bit more for the RB25, BUT you'll see MAJOR amounts more torque.
Much better engine all around.
Yeah i know but with the mods i have i'll need to get a new ecu, dial in the cams again, get it tuned etc. If i just put 20 back in i'll have awesome power as is. Had 267atw with current mods.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
