well put^^^
would have loved to been there, i had a display at final battle 06 right next to the dyno and damn it was awesome watching it pump out 761awkw back then let alone almost 1000.
Edited by 2BNVS
  • Replies 126
Posted Images
well done. that is a bullshit amount of power! hard to even comprehend what it must be like to drive it hard. :)
How can you possibly drive a car that powerful at full noise and stop it flipping itself onto is roof ;)
some perspective...its more than double the power of out our circuit GTR and almost double what our 9 second drag car puts out.
absolutely awesome machine. well done boys. Just a few $$ in that package i'm sure.
930hp ATW is an amazing feat. 930Kw ATW is just insane. I find it difficult to comprehend what that must be like to limiter launch.
Interesting, so its gone from a JUN 2.7 with a Trust T88-38GK to a 2.6 with a Garrett GT47-88?
Edited and yes, that's how I understand it, mate. But Mark is in the thread so I'm sure I'll be corrected if I'm wrong.
Interesting, so its gone from a JUN 2.7 with a Trust T88-38GK to a 2.6?
CRD's old engine is sitting complete in Marks workshop...
New engine is a 2.6ltr Godzilla item...yes factory bore and stroke.
the only part of the engine package left from CRD was the intercooler...it failed on the last run splitting the end tank off it...so i guess now that its gone its a total Godzilla package.
yes 2rismo you are correct GT47-88
Edited by DiRTgarage
Huge well done to John, Mark and the boys at Godzilla!!! These guys worked hard on this car and still managed to get customers' cars through the workshop at the same time. Very impressive indeed. I'm glad to see the hard work has payed off guys!
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
