  • Replies 126
Posted Images
On Parramatta Rd on the way home after watching RH9 I had a car of punks ask me if I was the owner of RH9 (still have the Godzilla Motorsport stickers on the side of my van from WSID) I was tempted to say yes, but sadly had to say no.
Awesome effort, very well done!!!
What fuel and how much boost was chucked at it to pull 930wkw??
Also, big well done to the RH9 R34, has it run a 9 at the strip yet?
Rob
C16 was the fuel...ill let you do the maths to work out the boost. :(
it may skip the 9 second bracket and go straight into the 8's...damn...it may spoil my plans to be Australia's next 8 second GTR
Edited by DiRTgarage
Rob
Not one pass under 10.00 in the 4-5 years the stickers/plates have been on the car :)
I watched that Vid too... they almost spooled very similar, that was cool :)
C16 was the fuel...ill let you do the maths to work out the boost. :)
yeh, it'll go from 13's to 8's with the right box/tyres/susp. setup/enough nitrous off the line in no time
Hi guys and thanks.
I would like to take the opportunity to thank Mark, Shane, Harry, Justin from Godzilla Motorsport and Gonzo for all there help in making our weekend as succesfull as it was. To all my family and friends that made there way to sydney for all there support.
It was a shame the intercooler let go on the last run as we would've given everyone a nice suprise at the outcome (it's a miracle what another 5psi can do).
I am looking forward to racing at Willowbank with Mark and the team early next year and getting the car down the track as thats the reason it was built,
and the reason Mark is spending so much time on it.
We will keep you updated.
Geees Paul i thought you'd be happy about me skipping the nines???!!!!
John
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
