does any one konw if the gas supra went on the dyno?
GAS2JZ won the weekend with the msot power...jsut over 1000 kilowats...was crazy cuz it sounded like a normal engine at idle and still had all it's interior etc...
btw did i say it ran 4 times 1000KW runs on the weekend??
and mis 52j cracked over 1000 horses...she was so happy...that car is very very nice :P
  • Replies 126
Posted Images
Cheers man
What is the best time on the quarter that r34 has run so far??? The RH9 one. Surley it can't be a RH9 with that power.
Be nice to know.
Mick.
Hey Mick, how's things....good to see you here downunder.
I think its just best to wait and see, instead of speculating. Mark has changed the set-up a lot and it has yet to be fully tested at the track. Lets just see what the new year brings.
Paul
Paul
Hi Paul.
Great to be here dude. I take your comments on board.
I got to congratulate you on your success with the 32 dude :(:)
Fooking Awesome.
Mick
Hi Paul.
Fooking Awesome.
Mick
Thanks Mick, the 32 is now part of the Godzilla Team....and Mark has helped step the car up a level to now be a more serious track car. It will probably debut with its new set-up when RH9 is ready.
Awesome Paul.
I will be watching.
Mick
Heres a pic I took yesterday
fk me ragged! that is one large sized turbo. all I can think of is how much that puppy must weigh! you must have one strong mani to hold the thing up when it's expelling 800 degree gas. :)
thick walled steam pipe manifolds FTW
it weighs around 30kg
its sold..its not sold...its sold...its now a track car..your worse than a woman trying to workout what she's going to wear today :)
Last I heard, CRD couldn't give either Paul (DiRTGarage) or John (RH9) the time they needed trackside, so they both went to Godzilla motorsport... the boys there just happen to live trackside :)
Well done to John and all the boys at Godzilla motorsport, super effort! I'm just happy that it beat the Gas R34... wouldn't that be a slap in the face :)
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
