Has it got the sequential box back in it?
RH9? There's enough power to run a 7 :thumbsup:
What box is in it, Paul? And will it be running in the fastest street car comp at WSID next month? :D
i asked that question 5 pages ago :)
Edited by TiTAN
  • Replies 126
Posted Images
Went down to JEM last night, and found out they used Adams Mainline for the AutoSalon.
What was it that gave it away? The big JEM stickers on the dyno or the big ones on the control unit in all the photos and video from the event?
(Apologies if you didn't attend the event - it just read like you had been super-sleuthing.) :(
LOL!
First of all i would like to say well done to all involved 1250hp is very impresive.
What would be the cost involved in building a engine like this complete with turbos etc?
1 very hot wife,
1 small child
Left arm
Right leg
And a patridge in a pear tree!
$60k would do it I should think. How many would you like?
60k thats a bargain to make an extra 200hp atw compared to when it had the crd 2.7 in it.
since the 2.7 is tired and no longer of use i would be interested in purchasing it so please if its for sale shoot me a pm
thanx Paul
probably due to the fact it mite be running some 15" drag rims and a parachute now? :banana:
So when is this bad boy going to hit the strip? And on that topic, why on earth has GAS2JZ not hit the 1/4 mile either? That would be fricken cool to see :angry:
rh9 will be hitting the track in jan 09 with drag radials...
it will not be running the nitrous for the drags.. and about 1000hp at the wheels...
we will seee if the gearbox is up to the job...ha ha..
cheers, mark
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
