Evening all,
I have a 32 GTSt that i'll be building a 30 for and would like some advice on how to satisfy VicRoads and Insurance etc etc.
Just wondering what anyone has done to get their car "legal" with an RB30.
As the 30 wasnt an option from standard just looking for some past experiences as to what problems you may have run into and how you got around them.
Thanks all - Looking forward to the dirty 30!
https://www.sau.com.au/forums/topic/248893-registering-and-legal-stuff/
  • Replies 56
Posted Images
I have been through a similar line of thought with a past vehicle.. this time, I'm going to make it look like the engine is standard and restamp my 'old' numbers into the 'new' block. Not exactly what you were after, i know. But been there, done that before. Cost me a bit to much coin and wasted a few days for my efforts..
Please let us all know how you get on..
Looks like im going to have to go through this in a few months before rego comes up.
I've been told that you should have an engineers certificate for the engine conversion before updating the rego papers. AFAIK thats about all it takes.
You cant register it legally, there was no twin cam RB30, its not EPA legal, ADR approved etc etc
That's the only downside to 30DET really.
Realistically all you can do is not tell VicRoads... but as you say if something does come up, if insurance does come into it for some reason, the you will be invalid/void with regards to insurance
Also with regards to re-stamping - i believe there are laws & restrictions around that
Insurance can only be void IF they can prove that the modification in question was the reason for the accident.
eg: If you have an aftermarket control arm and it snaps, causing the accident, and they could prove it, then yes your insurance is void because aftermarket control arm are illegal.
But they can not void your insurance because you have a bov, two intake mods, etc, when you have run up the back of a car or whatever.
That has come straight from an insurance representative.
Thanks for the responses gents - keep the coming.
What if I obtained an engineers certificate? Could the car be registered on that basis?
Or
Perhaps I could tell them its an RB25DET? they wouldn't be able to tell that its the 3l bottom end...
Hmm - I may give them a call and find out what the go is.
I'll report back for all those interested.
Thanks again, and if you have any other helpful info I'd love to hear it.
Cheers,
Ok,
So I have chatted with VicRoads as follows;
You need to obtain approval from one of their VASS (Vehicle Assessment Signatory Scheme) engineers. They have a list available from the VicRoads website.
I contacted one of them and they said they go over the whole car and identify any areas of concern i.e. mounting points etc etc to check that the conversion is "acceptable"
At a cost of $880 + GST ($968) they will provide you with their approval certificate. Provided your car passes this test you CAN register the vehicle as per normal.
Just an update - I'll keep fishing for a better price yet I don't think I'll find to much cheaper.
Yup pretty much what I was told too.
I believe the ADR's allow for a 25% capacity increase without requiring an engineers certificate.
For a car locally delivered - VicRoads here is a pain, there is a fking sub-law/rule for every ADR in the book.
That law is there, but if you own an import it whats classed as a "high risk" category car and needs to be VASS approved here in Vic.
I got shafted going from RB25 to RB26 (no other change), i couldnt do it without a VASS even though it was under the % increase & the % power increase laws because it was 'an import'... :)
Sherrif - Read what i posted :)
I've been (unfortunately) through the EPA/VASS/VicRoads wringer more than i would have liked...
You cannot legally get a VASS for a motor that has not been through testing EPA/ADR wise.
The RB25DET is fine, RB26DETT is fine, RB30DET is not.
Nissan didnt offer it, there is no data on the motor, so IMO getting a VASS is a waste of money as its in no way legal or valid in any way shape or form.
By the way, a VASS Should be $500-$550, or $650 if a brake test is required - so whoever you called is ripping you off.
To get a justified VASS, you will need to have the motor fully emissions tested, which will probably cost more than the motor.
PM me if you need/have questions. I dont mind helping out, if i can avoid someone getting shafted as hard as i did with my conversions its a bonus as far as i see it.
I got shafted going from RB25 to RB26 (no other change), i couldnt do it without a VASS even though it was under the % increase & the % power increase laws because it was 'an import'... :D
lol so they're no longer really ADR's in vicco but VDR's!
Pretty sure here if it's less than 25% capacity increase (and possibly in the same engine layout i.e turbo i6) then all you need to do is ring up and change the engine number. That's what I was initially going to do but I got a yellow sticker (defect notice) before I had a chance to call up, because my bonnet didn't shut properly :) So took it over the pits shtting myself about having mismatching numbers and turned out it wasn't a drama at all!
ADR's are only referred to really if there is no Vic Ruling... of which there are far too many, and most of them far too dated, most date to the mid/early 90's
Even the EPA sheets date back that far for some things.
Over there you can do that, over here you cant
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
