Ok, I have a strange one, not sure if anyone will know the answer for, but before I go tearing stuff out, and hacking in the car, I thought I would see what others think on here...
I have a 93 model R32 GTR Skyline, great car, is serving me very well.
A while ago, had a little accident in her, no biggy, but basically put the entire left hand side into a wall, went steerings arms, control arms, panels, etc.
Got it back 2 weeks ago from the repairer, and she has been driving nice, had a wheel alignment and it's as straight as a dye. Anyway, until the weekend, I used it to putter around the city.
The issue: I have found that when I am on the highway, pushing through a nice open wide sweeping corner right, the rear left feels like it drops in height and the entire back of the car seems to shift about half - 1 foot sideways as you sweep through the corner. Quite dis-concerning as it happens, it feels like the back of the car is sliding (This is for sweeping right hand corners, weight transfer to the rear left).
If I pull the same maneuver in a sweeping left hand corner, there is no issues at all, it holds hard and fast, and power's through terrific.
Now, if I apply power as I am going through the sweeping right hand corner, the car seems to stay fairly stable feeling, but if I go to change gears, it gets all out of shape and wobbly again.
Not sure if it's something to do with damaged HICAS, or if something is not bolted in right, but I dont have this issue at low speeds, only seems to occur above 50km/h.
Anyone got any ideas before I go pulling the rear of the car apart tonight?
Thanks,
Brian.
https://www.sau.com.au/forums/topic/248920-steering-issue-in-the-rear/
i would say it is a problem with the HICAS. as it only comes into play at speed as far as i know.. why dont u just buy a canceller bar 2 get back some rear end stability into the car.
that. or what i think it could be is that the rear toe is out. if it never happened before that means that the hicas was working prior to it happening. hence why he hadn't felt a change until after the accident. i know from personal experience.
I have had everything aligned, rear toe and front toe have been adjusted, and I am planning on getting rid of the HICAS as well, but wasn't sure if there was anything else it could be....
There is a list of minor issues I am pestering the repairer about in regards to his work, and this is one of them, as the never had issues prior to repair, but does after the repair. Due to the issue being whent he car's weight load is pushed to the left side (sweeping right hand turns), I believe it's something damaged from the accident.
I will investigate further and see what I can find.
Thanks guys,
B.
k then. if it's not the hicas. try looking at your sub-frame bushes. check for leakage & tears in the rubber. u might have to get under there and get the bolt out to get a good look at the bushes though. apart form that u say teht they just did all alignment and id ay they would have thought of the swaybar being loose so that should be all good.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
    • You would need to paint your hardtop again though
