The spec S non turbo exists in Japan however it can't be imported as it doesn't meet the power to wight ratio to make it an eligible import. The Autech non turbo version is eligible however.
There are around 25000 spec R's made that we can import up to 08/2000 but only around 200 Autech non turbo versions meaning that are are few and far between in Japan and at the current exchange rate not much cheaper than the turbo version so I doubt you will see any of these come into Australia for a while.
Jon @ Carizma
https://www.sau.com.au/forums/topic/248924-non-turbo-s15/#findComment-4317615
I've been in an Autech S15 and it's not bad. With a pod filter on, the induction note sounds like VTEC.
That said, I'm not sure if it's this specific example but it was down on power. I think it only managed around 100rwkW at a dyno night I went to. Everyone was reading low that night, but that's really low.
Without the turbocharger to make up the midrange torque, it definitely doesn't feel as fast as an SR20DET making the same peak power.
https://www.sau.com.au/forums/topic/248924-non-turbo-s15/#findComment-4317788
We get them in NZ. Cheap as balls. Why? Because they suck. Last one i saw sat on a lot for 9 months. Had full exhaust and a mean set of headers too.
I just dont think anyone buys an S15 for the hell of it. They want the turbo. haha
https://www.sau.com.au/forums/topic/248924-non-turbo-s15/#findComment-4318298
I wouldn't call 100rwkw for a NA 2.0 four cylinder "really low". Certainly nothing too flash, but compared to Aus spec S14 and S15 SR20det's which make around 120rwkw its not too bad.
https://www.sau.com.au/forums/topic/248924-non-turbo-s15/#findComment-4325610
I would call 100rwkW for a car claiming to have 147kW at the flywheel "really low", since it's the same quoted power that the 120rwkW SR20DET makes. Considering it's practically the same drivetrain, you can't even claim differences due to parasitic loss.
If it was a standard Nissan SR20DE then yeah, it's a pretty high number. But for an engine with uprated internals, cams, tuned-length exhaust manifold, etc, it's disappointing. B18Cs and K20As will make more power than that.
https://www.sau.com.au/forums/topic/248924-non-turbo-s15/#findComment-4327699
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
