HALP HALP!!
i got GT5 yesterday
finished C class. and saved and bought an R35 GTR
but the question is.
how come it keeps sliding? and secondly. can you do up the cars like in GT4?
i'de love to add some new rims to my suzuki cuppacino :(
https://www.sau.com.au/forums/topic/248965-gt5-p-halp/
can't change wheels;
if i remember right once you get to A class or something you can start tuning the car (just increase the power, decreasing the weight, changing suspension setup and changing gear ratio)
can't answer the question about the R35 GTR maybe its just your driving style
https://www.sau.com.au/forums/topic/248965-gt5-p-halp/#findComment-4319602
hey i've got it, once you complete all of the races C - A class, you can then tune, but that is about all, keep in mind its only the Prologue (i believe its only half of whats in the full game)
I havent played in a few weeks, but when taking a corner, you need to keep on the accelerator, even just slightly, if not youll begin to lose traction and bang!
so ideally, slow down heaps as you get to the start of the corner and power through it.
hope this helps
Steve
https://www.sau.com.au/forums/topic/248965-gt5-p-halp/#findComment-4319865
THANKS STEVE!
but it seems to just power down when i accelerate while turning..
id'e hate to say, but the EVO drove nicer than the GTR. just a great lil car to drive.
the GTR is good fun tho, sliding around the corners.
i got the physics thing set to pro because im just that good :( but all the friggin GTR's keep hitting me and penalising me in the GTR race at the dealers
https://www.sau.com.au/forums/topic/248965-gt5-p-halp/#findComment-4319901
ffs cant get past the integra race where u gotta pass everyone in class B
lol its pretty tough, but it is possible,
don't worry about hitting other cars, just go hard, use them as bumpers around corners if necessary, i dont think you get penalised for it, so go hard!
https://www.sau.com.au/forums/topic/248965-gt5-p-halp/#findComment-4324291
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
