Wtb R32 Gts Parts In Vic Seats Brakes Exhaust Afm
wanted for R32
front and rear brakes including rotors calipers flex lines 5 stud turbo (hard lines to master on front would be nice)
driver and passenger door trims black
indicator stalk and cover
steering wheel
driver and passenger door seals
passenger side front guard
4 caster tops from front and rear shocks, a set of standard shocks will do
2 front headlights
2 tail lights
2 front indicators
std rb20det AFM
front drivers seat black cloth
rear 2 peice seat
full exhaust from turbo (std or aftermarket)
not looking for anything brand new, gtr spec or custom just some left over stuff you may have laying around
PM as i will check here offen
will to pickup in victoria but am traveling to goldcoast during christmas break
thx
ok heres the list of pretty much everything i need
i just got a R32 missing alotta parts
brakes
front and rear calipers rotors nuts/bolts pads and the tin cover for 5stud turbo
solid front lines from booster and flex lines
solid rear brake lines (just the small section from the booster to the alloy block about 100mm long)
drivers seat
rear 2 piece seat
passenger side guard
passenger side metal door catch
drivers side electric window mechanism
both front door trims (bare)
front lights and indicators
tail lights and reverse lights
full exhaust (std or aftermarket) turbo back
passenger side and center dash vent
cluster and surround
heater control box and surround
indicator stalk
steering wheel and boss
RB20Det air flow meter
std airbox/pod
and the 4 caster tops from the suspension (crazy i know)
pm me with what ya got and what ya want for them
im in S.E suburbs
I've got a full set of R32 GTR brakes if you're interested. I have a thread on here about it. Let me know if interested.
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
    • I dunno what the "best" one is....but when my 040 died late last year, after about 20 years of screaming service....I put in a 255. Like any such thing, you have to finagle it a little bit - it's not a no-brain swap. But it's not hard.
