Hey Guys,
Just wanted opinions and ideas and to see if anyone has come across this issue.
I haven't driven my R33 in about a month or so (company car) and the missus drove it last week and said it was "jumpy" when she accelerated. So i took it for a burn this arvo after work and it idles like it's a boxer/rotary. It seems to idle fine for 2 secs then sounds like a misfire for 2 then back to normal. When it accelerates under load (driving) it feels like it is mis firing and every so often i get a nice bang out the exhaust when i change from 1st > 2nd or 2nd > 3rd.
I was thinking an intake issue, maybe air escaping from the FMIC Piping. The missus said before it wouldn't make boost when she drove it (or barely made it) but when i drove it it seemed it made boost maybe a lil below normal.
When i decelerate and run down the gears while breaking it revs fine it only has problems when accelerating.
Any Ideas??
https://www.sau.com.au/forums/topic/249030-helpr33-gts-t-not-running-right/
Remember this one for the future as its with most cars.
If it sounds like a rex/rotary, it means one or more of the cylinders isn't firing (unless its a rex/rotary lol).
Easy way to check what cylinder it is, while the car is running, unplug coilpack number one and see if the note changes. If it does it aint that one. Plug it back in and continue to do all of them until you find one that doesn't change the exhaust note. That is the cylinder the car isn't firing on. Could be as simple as a loose plug connection on the coil pack or a faulty coil pack or plug.
Pretty easy really :(
Oh ok, i didn't cross my mind cause i changed the plugs (and yes correct gap) about 3 or so months before it sat for a while. I will def check em again, hopefully it is the issue and fingers crossed only a spark plug. was thinking electrical connectors tho cause it has been raining a bit here lately and very moist air (Darwin)
Anywho i will give it a go and post my findings.
if it is misfiring on accelleration i would say its a coil pack that has gone. as they only play up under boost usually. during back off the engine is ander vac so they dont play up. just check the all out./
    • Yep I will use a guide coat after putting filler, I will do it on the whole panel as I'm a beginner so chances I've made quite a few errors. In that photo, I think that was a low spot, I just for example said to pretend it's flat but I will put filler + guide coat after to assess where I'm at. Yep with that picture, the panel is wet as it rained when I took the photo. But all those scratches are completely smooth, I went over it with 240 grit and can't feel it, even with my nail digging into it. I was legit thinking to buy a 2k can and spray primer to see how it turns out but then thought to myself it's going to be a mess doing it haha. Good mention there. Thanks for all that info I think I know what to do next.
    • Prior to laying down the primer, you need to make sure the surface is completely level. For example, based on this picture, I strongly suspect that the areas marked in blue are higher then the area marked in green.  If you spray primer over this entire area, then paint and clear it, the finished result will 100% show the low area. It will stick out like dogs balls. Unfortunately the paint won't magically level out the low areas as you lay it down.  Without seeing it in person, I expect that the green area will need to be filled, then use a guide coat and check that the entire repair area is level with a large sanding block.  With this picture, are you saying that even though you can see the scratches, the panel is in fact completely smooth and flat? If this is the case sure you could prep and paint it as it is.     The picture with the paint you described as blistering, it's hard for me to comment on from the photo alone. It looks like the panel is wet? Dunno, looks strange. Does the panel feel as smooth as glass when you run your hand over it? **** Going back to your question again, generally you would only sand the primer if you made a mistake while laying down the primer.  If the panel is prepped properly and you lay the primer down properly, you should not need to sand the primer.  This wouldn't work - Don't prep the panel. Spray primer and see how it turns out. Sand the areas where the issues appear. Spray more primer and see how it turns out. Sand the areas....... Yeah you'd go round and round in circles getting no where.
    • That's sick, thanks for that, mine has much the same mods on a 400R. I just don't have the heat exchanger yet.   Might be worth a trip down the M1 to Syndey for a tune.
    • Mate , this is the current mods list Current Mods list (Installed) RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler AMS Alpha Performance Full Race Down Pipes ECUTEK tune form TuneHouse in Sydney .(Just over 2k) The car came with HKS - Power Editor but I had it removed for the full tune. I would say if you are using the car for street diving a proper tune would be better.
    • Interested to see any videos of this or on the dyno. Mine currently has HKS secondary cats i am undecided if I want to remove them. What did it set you back to get the tube done? And what mods have you got to get that power? I was looking at a racebox flash tune but maybe a proper tune would be better if these guys are good.
