  • Replies 99
internal, and he is probably looking at needing to run ~15-17psi
Correct - Its internal but I plan on running about 20psi from the turbo (17 - 18psi at the manifold).
I'm getting a new turbo aswell. HKS 2510 :):thumbsup::D;):banana:
2510? Thats a bit small for an RB20 isnt it?
That's what he is after, something small and responsive.
Fair enough but I think that a better option would be an HKS GT28/35 Pro S - Extremely responsive turbo but big enough for real power gains.
Im expecting the 30/76 to reach full boost (20psi) at around 4000 - 4500rpm, it should start building boost from around 2200 - 2500 though.
Im not 100% sure though, your best off asking someone who uses a GT30/76 already.
mine starts building at 2500-3000 i get full boost at 3500
so 20 psi at 4 sounds about right
Its not how small it is but how you use it
I should be getting full boost (20psi) around 2500-2800, boost coming on around 1500-1800, and hoping to get 200kw at the rears or more, but with a mega torque curve (for a rb20)
Should be able to use 3rd when I was needing 2nd before at wakie, and I wont bog down as much at motorkhana's/Drifting
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
