Hi guys
OK here is the prob.
I recently purchased a Stagea that was advertised here and on ebay.
It's a great car and I got it for a good price :(
There were a couple of snags though.
It was advertised as having an alarm and immobiliser.
After seeing the car i realised all was not as it seemed.
There was no alarm/immobiliser and the car was registered in SA which was a surprise cause the guy selling it lived in Sydney.
I got an alarm fitted straight away which cost me about $700 which was a little annoying.
But i'm scared that when i go for the blue slip things will turn ugly.
The main concern i have is the glass in the car.
The front windows are tinted but i believe they are not so dark as to be illegal but the back windows a VERY dark
and they aren't tinted they are dark glass. They look fantastic but if i fail on them i'm screwed as i can't just peel the tint off.
Does anyone know where the best place to go is for a blueslip? And by best i mean least picky. I live in Wollongong NSW.
I need to get this done ASAP cause i'm assuming that the guy i bought the car from will eventually cancel the rego on me.
I know there would be people here who have had to deal with similar situations before and i'm hoping to use there experience.
Thanks in advance guys.
https://www.sau.com.au/forums/topic/249077-blue-slip-help-in-nsw/
We're VIC based, but hopefully this gets you started in the right direction:
www.rta.nsw.gov.au/registration/downloads/vsi/vsi03_rev3.pdf
good luck!
david @ Carizma
Hi guys
It's a great car and I got it for a good price :)
My car went through blue slip in NSW with limo tint on rear drivers and passengers / normal fronts.....
just have a go and see what happens. Don't panic until you need to ...LOL :D
I have just had the car retinted and it looks smik as.......$200 at endrust
Edited by blackheart
That's sounding like the 'UV Cut' glass which came from the factory on later model imports (eg R34s, etc). It's a factory-fitted option, so it should be okay...
Hi guys
It's a great car and I got it for a good price :D
g day
mate u should have no probs is it over 10yrs u want need to go to the viu unit (rta) which costs $411
just get a local guy if the front screen is tinted (whole screen ) then uv got problems only allowed to have a band up top of screen but nowadays u shouldnt have probs getting another screen . the previous owner cant cancell ur reg if uv got the rego papers transfered into ur name if its still regoed in s.a u can still drive it hope this helps you
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
