ok, i am running a rb226 harness on my rb25, and there are many differances, the biggest obstacle in front of me is the knock sensor harness and sensor them selves, on the rb25 the harness is intergrated into the lower harness, and they are green, on the rb26 they are black with a bolt through them, my first question can i splice my old sensors into the rb26 harness, or should i run the rb26 sensors, on top of that, does any other motor cross refence to the knock sensor harness since i do not have a rb26 harness perhaps a sr or ca ? any advice or input is apprecited, also i am running a power fc, so i know that i dont need the sensor (pfc does not retard timing like stock ecu) but i want it for the exta safety ( i have a wideband o2 as well as a egt sensor)
yeh i noticed lol
if the two sensors read the same voltage i think it would work, if u just ran theknock senors directly to the ecu, using rb25 harness, going to rb26 ecu plug
I am putting the RB26DETT head on my Neo RB25DET Block, so my plan is to swap over the upper part of the RB26 harness onto my RB25DET harness inclusive of the injectors and resistor pack and whatnot. Getting the damaged RB26DETT engine this weekend.
sounds good in theory but rb25 use 1 wire type knock sensor. rb26 run 2 wire knock sensor. gotta get my hands on wiring diagram to make sure which wire does wat.
yeah i was looking for a diagram as we speak, i hope its a power ground think since the 25 is tied into lower harness and is grounded there
yeh i was thinking along the same lines.... wasnt sure if the 26 may use individual grounds or not... tis all
yeah i know that only one wire goes to the ecu plug so i assume its a ground, any luck on wiring diagram, i do happen to have the two types of sensors on hand
waiting on a mate who has got them... not as of yet tho. i had a crazy thought of gettin the original knock sensors off the 25 and retrofitting them to the 26 block only problem is i would have to drill the block to make them fit due to the different thread size. not sure if this is even a valid option... probably not lol. if ne one else has ne ideas would be gr8 to hear.
