  • Replies 89
Posted Images
R-RATED - Its only a sort motor stripped and is dead ( spun rod bearing ) and I used the rest for my 25/30 motor build.
FLY-910 I'll measure them tomorrow and PM you
sr180sx - Its no a ABS model
Calipers and rotors are now SOLD
Front driverside head light with the chrome light surrounds in good condition $150
Spare drivers side door in gunmetal grey, stripped out, has a small dent, includes door trim $120
Front castor rods in perfect condition, rubberes not cracked $80.
Yep it did have a slight crack from the impact. I have reciently taken that side off and it poped back into shape and I plastic welded the crack back into place. Also there a some paint scrapes on it as years ago I had to run over a piece of tire on the expressway to avoid an accident. The other side is fine. $150 for the pair INCLUDING the rear pods
Hey mate,
Looking for the plastic piece that sits around the steering coloumn and the ignition barrel, if you have them could you throw up some pics n give me an indication of price?
Cheers
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
