hi there,i want to run a big single turbo on my GTR,first question is running a big turbo on a gtr is it required that i rebuild the motor,or maybe the question is whats the biggest turbo i can run on a standard motor,im not opening the motor yet apart from HKS step 2 cams and gears.i do understand its not going to get much boost in a standard motor,but i want to see what i can make without opening the bottom end.the cams will help with high cylinder pressures
i have a T88-34D and can also get a GT45.and iv heard i can get a TO4Z
i know what the first question will be and yes i dont care about lag,there will be heaps and i know,i use to own and pilot a 7 second rx3,so i know what it takes to drive something like this.
im not new to GTRs but have always just been a sheep and run small singles.i want big.
any and all advise is greatly appreciated .
You can make any figure, how long will it last though?
If you want it to last - GT35, about as big as you can push a stock bottom end reliably.
Otherwise, if you have the money there for the rebuild, boost away with whatever your wallet can afford
Big turbos... which make big power... and stock bottom ends, don't last. So no point having a big turbo if your not chasing big power
Im running a t04z on my GTR and it goes good. After a few problems with fuel delivery i've now got 337awkw's at 14psi. Stock bottom end with 260 Tomei poncams , Vipec ecu and supporting mods.
It is abit laggy, fullboost is at 4500rpm which isnt too bad, considering the n1 turbos i was running before was 4000rpm.
But im not going to be running anymore boost until i rebuild the engine as it simply wont last.
i just spoke to my machanic and he sugested the to4z.he said 350-375 kws....
im also looking at a GT45,the machanic has a R33 GTR with one of these big boys on it,runs 18psi and make over 650hp.
yes the bottom end is done but it was metioned that it was driveing on 12psi for 12 months making 510hp all day everyday before the bottom end rebuid.
350-370rwkw is right in the meat for GT35 territory mate :nyaanyaa:
a T04Z will run off 440rwkw, so unless your looking for that...
There is a big thread on GT35/T04Z going at the moment with lots of information for either side so you can make your own call there
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
