Hey Brendan,
You can contact the speedworks crew on 9242 8888. They are located at 4 Carbon Ct in Ossie Park.
I have not had any work done by them but i have spoken to them and they have been quite helpful.
Hope this helps
https://www.sau.com.au/forums/topic/24909-speed-works/#findComment-528979
