Yeah well, all of us think Sumo is a dick.... even the people who gave him the job think hes a dick.
They can tune just about anything except for F-Con i think due to the software being in japanese. I think in terms of what they reccomend customers buy... in general its Motec that gets the nod (or more recently a remap via BiKiRoM). But if youve already got the ecu then they'll quite happily help out :P
Red17
Red17
Heh heh, I didnt want to mention names :)
If they think SUMO is a dick why is he still employed there ... I have spoken to various people and workshops and they always crap on how good they are and the other guys shit .. never got anythink nice to say
who are you?
Brett: I think Speedworks don't do Apexi PFC's because they were told by JUN themselves not to - apparently they can't get the proper tuning required without the stuff that apexi loan out, and the h/c isn't good enough. Whereas that datalogit fc stuff apparently works REALLY well, and can tune to temperature (which apparently Apexi PFC's + H/C can't..? Could be wrong on that one though)
Its sad the APA dyno is at Rover tech because we were going to buy a 4wd dyno last year but organized with Ivan to hire his for our 4wd work but theirs no way im going to put up with Dave so i'm going to need to spend the extra cash on upgradeing to a Dyno Dynamics 4wd Dyno soon.
I love it when I hear utter shit like this. JUN says touch your toes.... JUN says pat your head and rub your tummy.... JUN says bend over and.....
Pffffft what crap....... so JUN say DO NAWT TARCH COMPETITION... WILL BREAK YOUR MOWTA.... DONT NAWT TARCH OR WE NO GIVE YOU GOOD PRICE ON JUN COMPONANT...
Pffffffffft
JK
Originally posted by PSIKO
who are you?
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
