ok guys went home then roo and i pulled half the motor apart and found what was wrong
+1 turbo and wheel undamaged and in almost knew condition
+1 timing belt and adjusters ok and also like new
pulled off rocker covers and had good movement,cams in good condition with little wear,car has only 81,000km i suppose should be ok
checked compression in pistons and found they have bout 150psi in 1-5 pistons then a big fat 0 in piston 6
then after inspection found conrod 6 is nacked as piston stuck on top dead center,was able to push down so isnt seized,know have the fun job off pulling apart to see how bad
big fat - for my 1st turbo experience,is it easier to do in car or rip motor out ? id say out, ill need to borrow a hoist if anyone got one not using
bad news mate, if the rods been flopping around in the bore then i think it could have done some major damage or the piston might have broken it half. i hope its not to costly for ya.
We'll know the full story when we get the head off this weekend, then drop the sump. Worse case scenario, the broken rod has damaged the bore and maybe some. But we see no holes punched thru the block thats for sure.
Anyone know of a seized RB25 engine lying around anywhere to donate a rod and maybe a piston?
The ripper, was the oil drain hose from the turbo was some heater hose bent to the sump, which resulted in a 'crimped' hose limiting/stopping oil draining back into the sump. God there are some dodgy mechanics out there. :P
ouch, really bad news mate, and I agree with chad, if its flopped around the bore is going to be stuffed under the piston, if the main rod cap broke off expect a lot of damage in the sump ,crank ? which sounds like what happened if you can move it in the bore still you broke the main cap off the rod or broke the rod itself ? is there a hole in the block anywhere by number 6 ? it may have put a chunk out of the block to create the noise of something coming past you under the car ?
also , if you tear it down check the oil pump/galleries it may have failed to get that problem with oil starvation ?
easier to fix with the engine out ? plus its going to need machining anyway
sorry for the bad news , ask santa for some forged pistons and rods ?
Unlucky #6 hey
Any sign of detonation?
Piston/spark plug colour compared to the others ect..
Always best to try and diagnose why it happened so you can avoid it in the future.
I hope it's an easy fix for you (and Reuben).
Goodluck
Edited by madbung
Unlucky #6 hey
Goodluck
yeah no detonation in 6 just bit more oily than others, looks to be no holes in block but will see after get motor out i guess, seems it may have been quick break, but we we also see,thanks guys i hope its not that bad either,give my a good reason for new rings etc maybe more,see what $ are like after xmas, thanks to you roo for coming over for our boys session,looks to be you help me i help you at moment, always cool, chat to you on wkend
i had piston 6 go on my car also ages ago but was on the dyno when it happened so ijust did a full forged engine rebuild
i have a set of series 1 rb25 rods sitting at home in good nick but with pistons still connected if u interested in buying, but you'll have to buy all 6
We'll rip the engine down and then you'll know the full extent and what you'll be saving up for Damo.
I figured it was 'out of character' when the engine was turned over and #6 piston wasn't moving :P
Colour of the spark plugs were all good and consistent. #6 was wet from fuel. Even pressure in all cylinders except for #6.
I'm praying the rod broke clean and didn't touch the bore (unlikely, but one can hope). Turning the engine over makes no noises or obstructions to seize the crank. Who knows, we might be lucky ;)
But we'll know more on the weekend. Stock up on beer and bullshit Damo, we might be sharing it around. :)
let me know how much u want in case i have to go that way,thanks
I figured it was 'out of character' when the engine was turned over and #6 piston wasn't moving :/
I'm praying the rod broke clean and didn't touch the bore (unlikely, but one can hope). Turning the engine over makes no noises or obstructions to seize the crank. Who knows, we might be lucky :/
But we'll know more on the weekend. Stock up on beer and bullshit Damo, we might be sharing it around. :(
yeah wont need to stock up on the bullshit but may need to make trip to stock up the fridge
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
