A bloke told me that there is a different level of complaince if you import a car yourself to if an importer imports one and that i wouldn't be able to register a car thats been imported privatly?
or once its complied thats it? the car im talking about is already registered in a different state
sorry if i missed this in the search
https://www.sau.com.au/forums/topic/249153-different-levels-of-compliance/
the Bloke must have been talking about a persoanl import these cars are owned by someone more than 12months overseas and are allowed in under the personal import Scheme not RAWS so the only go thru an Engineers certification and mod plated to be allowed to register this differs for all states . this would mean if you moved interstate it may need to be rechecked and signed off by an engineer from that state.
In the Case your question is asking if you are a private person importing or a dealer imports a vehicle unders the Raws system they are all complied axactly to a national standard set by raws and would be able to register in any state.
So really you need to find out if the car was a personal import or a Raws complied car. for your own information Personal imports have a yellow type Id plaque stating the vin and personal import. for old Raws complied cars they are green ID plate and in the last time raws went crazy they changed it to purple colour with all details of raws compliance workshops name and Vin # etc ..
ask the seller for a photo of the import plate it should clearly state what type of import it is.
Hope this helps
Regards, Phil
Ahh that makes sense now thanks mate! im pretty sure he didn't own it for 12 months over there he just imported it, i'll get a photo of the import plate but i can see a purple plate in the engine bay pic i have, can't read any numbers though
thanks for your help
edit so it doesnt matter what the numbers are on the purple plate as long as its purple? see attached link for pic
http://img246.imageshack.us/img246/9347/dscengineax1.jpg
Edited by byebye
to be honest I would ring the relevant office in your state and state your case.
I own a personal import that I bought from interstate and for me (qld) it was a case of going to QT and registering it.
You don't need SEVS compliance, that personal import compliance plate is a federal scheme, so it's already qualified to be in the country.
Here in VIC, you'd need an engineer's certificate, I think NSW is the same. SA you just take it to regency I believe.
Anyways, like Chris said, check with your local state road agency to find out what you need to register a personal import (yellow plate).
cheers,
David @ Carizma
So i would have to get it complied to change states
  • 1 month later...
In relation to imports, I had a look at this site:
http://www.tradecarview.com/used_car/japan...?ps=25&so=2,
It provides a shipping estimator and Freight courier. I looked at the Skylines, Wrx and Evo's which are resonably priced.
I have no experience in this field and would like to know how much hoops do i have to jump to get this vehicle on the road in NSW ie RTA. Would i need engineers certificates or what ever cerificates ??????.
Some nice Imports in Japan, what are your thoughts.
Do a search on tradecarview and you'll find out what the general consensus is >_<
Aside from just being a place were dealers list their cars it is also were lazy arse people cut and paste images from and state it is some ones stock that supplies to them but half the time it is just some cheap piece of shit sitting in a dealers yard somewhere in Japan.
what are the requirements for xenon headlights and front windscreen replacement in regards to compliance?
i looked at a car from a backyard dealer who couldn't speak English very well and i'm sure he said that he doesn't bother removing the xenons or replacing the windscreen (although he said he was meant to) for compliance.
any help appreciated.
The headlights are supposed to be modified to accept H1 globes.
Windshield is usual part no. M1G4 for the 34 coupes, there could be others that pass the ADR as well, haven't seen the evidence recently.
Both headlights and windscreen have to be roadworthy as well of course, which is where you're more likely to run into problems rather than with the compliance of them.
David @ Carizma
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
