This falls into the same line as my questioning on the speed camera/radar deal. Same idea: any rules and regs to be found on dB requirements/ testing protocol?
Pretty sure the testing procedure is covered under ADR 83, details can be found in this document: http://www.ntc.gov.au/filemedia/Reports/Na...estSept2006.pdf
Each jurisdiction decides what noise level they will permit (i.e. DB) for each category of vehicle, but they are all supposed to follow the same testing procedure.
You could print a copy and keep it handy if you were ever tested, although they would probably just decide you were being a smart arse and get you for something else.
These are the same "people" who wouldn't pass my car on Friday because I didn't have an owners manual........
On the domestic level I had neighbours complain my stereo was too loud. The EPA wrote me a letter and eventually came around with test equipment. They set-up and did their tests. I turned the stereo up as loud as it would go. (past where I normally would).
The EPA guy advised that the noise level from traffic two streets away had a higher reading than my stereo which interfered and he could not measure the DB's from my rental with any accuracy. Complaint dismissed!
Needless to say I had a few more loud and late nights to thank my neighbours who could have either complained to me or joined in festivities. Oh and so I turned the Sub up. Subs get louder the further away you are from it. Some form of percussion grenade effect I think ;)
PS. Anyone ever not heard a Harley. Bad enough stock let alone after the baffles are removed. How do they pass noise tests?
Edited by Sinista32
Hoooollly crap. It would have taken all the self control I don't have to not explode in their face and call them names so bad it'd make Rodney Rude blush.
    • Welcome!  How long have you had it? And what colour is it?
    • "CAD" version 1.0 It will have a 15mm lip around the top for 6 × 5 or 6mm nutserts and fixtures (two on each of the three straight edges), and some pinch weld on any exposed edges, it has three mounting points, one of the power steering reservoir bolts, and two on the rad support, my 120mm hole saw will make short work of hole for the silicone joiner, with ample room for some pinch weld  I've also got enough Carbuilders "peel and stick" heat shield to cover the outside of it at the coolant expansion tank and on the engine side, as pictured, and internally on the lid and where the fuse box is, I've also got some thin, about 3mm, black 3M single sided sticky foam stuff that was left over after sealing some door drafts at home to help seal the lid As for the shape, it "sort of" matches the shape of the fuse box, so shouldn't look to "out of place" The lower area and hole for the intake will need pinch weld with a balloon on it to fully seal the hole and bottom of it, that will happen after it has been fabricated so I know exactly what size is required  Filter service has been trialed,  and so far it was a simple process  Just need to get some alloy, and then head into work to use the guillotine and break press in the workshop Hopefully it should be sorted in a week or two Guestimated outlay will be under a $50 for the stuff I don't have on hand (alloy, 6mm nutserts, the pinch weld, and wrinkle paint) Disclaimer: That's what the "voices in my head" are telling me how the filter box should end up getting done......lets see if they know what they are talking about
    • Have been polishing up the trailer rims as they had been sitting in the shed for a few years and are really in need of some love. This was after a couple of passes with chrome polish - coming up quite well ✅ .
    • Welcome aboard! Is your Skyline auto or manual? I'm assuming manual. Does it have any mods done yet?
    • Hey mate, the brown and grey plugs would usually go to the TPS, brown one goes on the bottom connector and grey is the top but isn't used unless the car is auto, your TPS looks different to mine though I've got a series 2 engine.
