Plates IN24NE
Not on rta system as needing repairs
Full year of rego
Slightly rolled onto its side stupid lsd locked on deaccelleration went into muddy bank
Note : 2 way lsd will not be in car, factory viscous lsd will be put in
No mods except turbo injectors and walbro fuel pump
Note: Car was not turbo before hand it was in the process of being converted
Serviced like a baby by a mechanic owner
Oil, filter, coolant, spark plugs, pwr steering fluid, gearbox oil, diff oil all recently changed
Only needs panel work, new front bar, new intrusion bar,
new headlights, new windscreen and some other bits etc
Suspension is all fixed, car is running and is drivable
80000KMS
I WILL NOT SEPERATE BITS!
In wollongong nsw
Pm, txt or call me
CHRIS 0423428670
https://www.sau.com.au/forums/topic/249184-r34-4-door-non-turbo-silver-s2-7000/
PRICE DROP $6000
I WANT THIS CAR GONE BEFORE I GO OVERSEAS JAN
Make an offer
Yes you can drive it home no problems!
Just contact me if you have questions
Come on guys this car is perfect for a repair or spare parts
You would make more money than 6k if you had the time to rip the car apart and sell bits
And a reminder this car does have the turbo brakes gearbox and driveline because it is the 2001 hicas model ER34
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
