hey mate
Im thinking of getting the hypergear turbo...wat u think of them? good for wat there worth?
Are you talking to me? if so, even though some of us have chats in this thread, pm me instead to keep this one tidier... but if your asking... they go well, but having a lil wastegate creep issues atm.... ie the boost is set to 15psi but leaks up to 17.x Psi, probably due to a larger amount of exhuast gases due to n/a high compression then standard gtst... looking at possibly going a bigger turbo in the future to stop this issue.
Unfortunetly I don't know what your car is... so can't say how it may go on it...
Adam
ext gate = easy to tell illegal... not that my setup isn't now... but I guess somewhat easier to hide with my custom heatsheild. Not to say I havent thought about it in the future.... ive been looking at int gate gt3076r's, but i've been in a skyline with an ext gate 300rwkw Trust Td06-20g and it is insane! and similar price... so both are an option :) cheers mate
Model - R32 Gtst
Engine - RB25DE
Modifications / Parts Used - Garret 3071r, kkr external gate & screamer, tune agent ex. manifold, greddy copy plenium, 60mm throtle body, cometic 1.8mm headgasket, nismo 550cc injectors, fmic, sard fuel pressure reg... etc.
Engine Management Used - apexi power fc
Fuel Used - BP Ultimate 98
Boost Used - 1 bar
Dyno Tune Results - 372.5HP
Misc- Other Details, on semi slick tyres (apparently this can effect the power reading)
Costs - Parts: roughly 5k
Dyno Graph -
Edited by RB_turbo_bitch
oh sweet! Once again goes to show how strong the DE's are! I thought you were running stock pistons just with new bearings till I read this in the article: "That’s why the engine has been rebuilt from the ground up and strengthened with ACL main and big end race bearings."
So what compression is it running now with that gasket? I've had a couple of tuners advise against doing the gasket method as with still running the N/A pistons the only benefit is running more boost and losing the high compression response, but I guess this proves that wrong to an extent, and if you had the engine opened for the bearings then from a cost point of view it makes sense to do the gasket as well.
How is it as far as temps go? Particularly between street driving and track. I notice there's no mention of oil coolers and bigger radiator. Is it simply a case of just not really necessary even on a high powered N/A+t build?
lol.. found the hpi huh. :laugh:
I have stock pistons, thats correct.
The stock RB25DE runs a 11:1 ratio, so with the thicker head gasket i think my DE+T is around 9.5:1.
With the radiator, my stock rb20 was rusted out and temps were getting as high as 100, so earlier this year (3 years on) i put a bigger alloy one in. On the street the temp sits at about 75, and on the track between 85 and 90. No oil cooler, just an oil change after every event to be on the safe side.
Im on my P's now with a rb25de with around 150,000 on the clock.
in about 8 months time i will be doing a turbo conversion.
is 200rwkw an easily achievable target and is there any major issues to look out for when doing this. some very nice cars and figures on here by the way.
lol.. found the hpi huh. :)
is this power at the flywheel,and the stock comp on the rb25de is 10:1 according to the manual
Model - R34 25GT 5spd
Engine - RB25DE+T
Modifications - Turbonetics Stage 2 T3/T04 turbo (laggy mofo) w/ 38mm turbosmart ultragate, fmic, GTR bov, 3" catback + 2.5" dump/front/cat, nismo adj fuel reg, r33 GTR fuel pump, Exedy sports tuff HD cushion button clutch
coming soon: 550cc hiflow injectors, 3" custom dump & front pipes, 3" hi flow cat, turbotech bleed valve @ 14psi & retune
Engine Management Used - eManage Ultimate + ignition chip for neo RB's
Fuel Used - 98 Octane (Mobil 8000 to be exact but i use V power, vortex & mobil)
Boost Used - 9 PSI but boost won't hold after 5500pm, it keeps rising.
Dyno Tune Results - 184.2 rwkw
Misc- boosting the c*nt up to 14-15 so hopefully net myself a good figure and some monsterous torque. atm it boost spikes & keeps climbing after 5500rpm, it hit 201 at 12-13psi @6400rpm. have since changed the wastegate spring to a softer and smaller spring (7psi which feels like a$$ now) so hopefully it fixes the boost issue, going to install a turbotech bleed valve and set it to 14psi and in for another dyno run in 2 weeks.
p.s it does hectic skids :down:
  • 5 weeks later...
  • 3 months later...
Engine - RB25DE+T
p.s it does hectic skids :)
changed to a 7psi spring & fixed boost creeping problem.
used a manual bleeder to set it to 10psi, tihs bleed held 10psi dead FLAT with no spike and it pulled 180rwkw & 499nM of torque.
car is going back in next weekend for a EBC tune 10psi (low) 14psi (high)
profec B Spec 2.
hopefully get some decent torque & power out of this.
if its near maxing my injectors & afms then im gonna go for 550cc hiflow + emanage map sensor and piss off the stock afm.
ideally i want to run 14psi on high boost but ill let the tuner do it slowly from 11psi and see which is safest without any knocking etc.
also got a 3" dump/front & catco cat as well, also removed the silencers from my exhaust so it shouldn;t be as restrictive as before.
one problem tho, im running 18" work vskf now so it might weight it down ;)
post up results/dyno sheet next weekend.
RB TUrbo BITCH at what RPM does it hit full boost?
  • 2 months later...
model, gts25 engine,rb25de
mods,r33gtst turbo,xs power 3"exhaust,480cc injectors,power fc,modified plenum,fmic,25 row oil coolerfuel, shell v-power
boost,10.13 psidyno,378 bhp atf,6670rpm
costs,parts £3100,labour £0graph, sorry thats an old dyno sheet i'll get a more recent one
got a remap today,extra mods are 62 degree thermostat,meth/water injection and upped the boost to 12.3 psi
i was just looking through this thread and saw the discussion about lammy426's power figures. you have to remember he is in england, and it's winter over there, so nice chilly air temps which will give much better power. if he was to bring it to australia and run it on a 30 degree day it would ping it's arse off and he would be making much less power. also lammy, you say "at the hubs" does that mean you are using a hub dyno? if so, they are known to give different results to wheel dynos
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
