i was just looking through this thread and saw the discussion about lammy426's power figures. you have to remember he is in england, and it's winter over there, so nice chilly air temps which will give much better power. if he was to bring it to australia and run it on a 30 degree day it would ping it's arse off and he would be making much less power. also lammy, you say "at the hubs" does that mean you are using a hub dyno? if so, they are known to give different results to wheel dynos
this one was done in winter but it was in a heated workshop,hub dyno's are more accurate than a wheel dyno ,and don't forget tiger white still as 10whp more than me but i don't know if theres much temp difference from aus to nz,anyway i still have a few bits to do so i might crack his record out of an rb25de+t
hub dynos might be more accurate than wheel dynos, but they often give totally different results. basically my point is, unless the 2 cars are run on the same dyno on the same day and tied down the same, you can't really compare them.
very true ,but i do look at gtst's dyno'd on the same one as mine,the one i have talked to at .85 bar only get around 280bhp ish ath. i've set my goal at 345+ same as tiger white, i don't know if i should get a topmount or a hybrid turbo my tuner said he can get more more power with a bigger wastegate because its creating heat what do you think, oh and he loves driving my car because theres no turbo lag and it'll outdo a gtst with more bhp,not top speed of course as i still have the 4.3 diff in
  • 1 month later...
my hiflo stocker arrived i'm going to alter the wastegate and actuator abit before i fit it
all done and dyno'd,now we have 395bhp ath at 15.3 psi,i nearly fell over when he told me ,well pleased
lets see how long it takes for it to blow up lol.
Whatd u do to it and how much mulaa did u have to throw at it? :rofl:
just made the wastegate bigger and fitted a collins 12 psi adjustable actuator,my tuner was just concerned about the hg blowing,what is mulaa
mulaa (moola) = money lol.
Turbo? internals? intake plenum?. You basically bolted on some parts and made close to 400hp?! :rofl:
this is what i've done over 4 years http://www.skylineowners.com/forum/showthread.php?t=142304 and with buying the car completely standard for £1905 and the mods have cost about £4000 with mapping
Hey all Thought I would post up mine as I got the car back from unigroup today.. A few little problems holding me back on power but should be an easy fix.
Model - R34 25GT
Engine - RB25DE
Modifications / Parts Used - R34 stock Turbo, Injectors, Manifold, 3 inch Dump/front pipe, Kakimoto Full Mega N1 exhaust, Walbro fuel pump
Engine Management Used - Power Fc with hand controller for R34 Neo
Fuel Used - BP Ultimate 98
Boost Used - 7 PSI
Dyno Tune Results - 160.5 KW at 6500 RPM
Misc- Went with the Power FC for the complete solution although there are a few problems that need to be sorted out. Like blocking the signal that looks for the TCS and sorting out how to operate the Solenoid that controls the valve in the Inlet manifold (if anyone knows a way to do this please let me know)
Costs - Parts: Aprox $2500, Labour: Free as I did all the work myself :blink: and Tune: $750
Allover things went really well.. A few unexpected problems, My VCT is switched off atm as its not getting a consistent amount of voltage so thats killing some power, Boost controller needs to get pulled apart to see what the problem is with it not sending the signal to the solenoid.. The only other real problem is the Valve solenoid thing in the throttle body/manifold, Have stuck it in the Top end range so its always open which is killing some of the low down power.. Having replaced the Stock ECU there is no signal to control it as its not on the GTT model.. If anyone else has had this problem before and found a way to solve it please let me know or if anyone can suggest some ways to control it im all ears.
Once these few problems are sorted It will push out an easy 180+ with real good torque (dont have the exact specs as its not tuned.)
Model - R34 25GT
Engine - RB25DE
Boost Used - 7 PSI
Cara (MissR34) may be able to help with the variable length manifold solenoid that you speak of... reason I suspect so is because she is running a PowerFC on her R34 RB25DE NEO.
Sounds good so far :sick: did your power curve taper off after 5500 RPM or is the power at 6500RPM your peak power? Well done doing all the work yourself, saves a hell of a lot in labour costs! Got pics of the engine bay?
I'll eventually get around to getting another power run done. There's been GReddy EBC, Gearbox Rebuild and Catback Upgrade since the last power run so hopefully should see some improvement.
Sounds good so far :yes: did your power curve taper off after 5500 RPM or is the power at 6500RPM your peak power? Well done doing all the work yourself, saves a hell of a lot in labour costs! Got pics of the engine bay?
I will have to check that out thanks N-dawg.
Peak power is at 6100rpm then tapers off to about 140kw at about 7000. Ill attach the dyno sheet so u can check it out.
I have a pic somewhere of the engine somewhere, just looks stock with all the stock piping etc.. just had to add a bit of 2.5" piping to reach the elbow onto the throttle body.
I managed to fix the boost controller today which is good.. the vaccum hose had been pulled off the part inside the boost controller itself, just loosened the clamp holding it on slid it back and redid the clamps.. Yay for easy fixes :) EBC is a Blitz Dual SBC with 4 presets.. I should set them to 8-9-10-11 haha stupid stock turbo, need to get a GT-RS i thinks..
VCT will be getting fixed on the 18th when it goes back for a retune and up the boost..
Any reason for running that boost level? Did you try more boost to see what the result would be?
Yeah the EBC was playing up and we couldnt figure it out so we could only use standard actuator pressure.. Gonna bump it up to 10 psi now that I fixed it then when the VCT is fixed up it will get a final tune. Will be looking at 180+ Ill get a torque curve as well to show.. Should be very fun at next Texi.. shame its soo far away..
Heres my long awaited (almost) finished product:
post-36975-1273579588_thumb.jpg + post-36975-1273579744_thumb.jpg = post-36975-1273579805_thumb.jpg =
and good times :thumbsup:
We actually got it 5kw shy of 300 but wanted to make it safe as possible: @18psi this has a max knock of 20 which is nothing
nice wastegate,good work,whats 283kw in bhp and is that with standard rb25de internals and head gasket,thanks john
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
    • Yup but for me its the HR ! Cut my teeth on the old holden 6s in the day ! And here's me thinking in the day it was also the 300ZX and the Mitsubishi GT3000 ! All, as well had good lines, but always seemed to need finishing off, style wise.
