cheers, its all standard internally :thumbsup:
from unitconverter.com.au:
284rwkw = 380hp
295rwkw = 395.6hp
I want to see when I set my electronic boost controller if I can have a few of these settings ie. high boost, mid boost, low boost :)
Adam
The only other real problem is the Valve solenoid thing in the throttle body/manifold, Have stuck it in the Top end range so its always open which is killing some of the low down power.. Having replaced the Stock ECU there is no signal to control it as its not on the GTT model.. If anyone else has had this problem before and found a way to solve it please let me know or if anyone can suggest some ways to control it im all ears.
The ECU pin that controls the baffle switches it open in the mid 4000rpm region in the 25GT. In the GTt this is the very same ECU output that opens the boost control solenoid to go from low to high boost in the late 4000rpm region. Basically it should still operate much the same if the output is still connected......is there a setting in the
PFC that controls this output? May be worth sticking a multimeter on the pin and seeing when it triggers +12v (or if it does with a PFC)
Thanks Dan, Ill pass on the info to unigroup to check it out as I dont have a multimeter..
Any ideas how I can disable the TPS for the traction control on the ECU?
Still gotta try and look over the VCT too its running 4v on the ground side of the circuit.. Not quite sure what to look for, Maybe just something that looks out of the ordinary.
Very impressive results WYTSKY
I'll have a look, I tricked the signal on a car years ago using the 5v TPS feed and some diodes running into the sensor wire of the TCS. As far as it was concerned it could see the ~2.5v it need to not throw up an error signal.
Just finished off making myself a heat shield, not the most overly pretty thing in the world but boy was it cheap :P
So here is a crappy phone camera pic of my engine bay for ya N-dawg.. completely stealth except for shiny shield but cant get defected for it anymore..
Gonna have to cover the heatshield with an assortment of jap stickers.. seeing as I have something from every major brand (nearly) on the car now.
my +t project is going on the dyno tomorrow - running a t3/t04e, hopefully the high compression will help spool the dinosaur turbo.
Did anyone here running the NEO RB25DE think about changing the intake manifold? or is the twin runner design superior to the DET manifold?
Adam you crazy mother fker, very impressive results mate :/
i'll hopefully be joining the 280-300 club soon but with a more reliable motor tho :P
not bad starting base aggroman, i guess u wont need my oil line anymore?
should hit 180+ with 12psi
How much did all the parts + labor cost for you wytsky? looking at chucking a turbo on my car as well but not sure if its a good idea long term
well, i did most of it myself. so depends how good you are with the tools. do you have an oil drain/oil return on your block? I cant remember the older stuff like manifold, gaskets, standard injectors etc etc as they were done years ago, so you need to do some reading to get all that sorted first.
hehe, cheers bud. i said to myself, i'll be happy if we get 260, absolutely satisfied at 280 and any more is just a bonus, i'll see what happens with the gizzmo ebc as we are just using the bleed valve atm which is fine, but the gizzmo gives me 6 different boost settings so wouldn't mind an extra psi or so to really crack into the 300's very very occasionally and have a few different combos.
Oooh I may finally be able to put a solid dyno figure up, someone SA was selling my old car, hopefully they put it on the dyno???
I love how it lost 105,000kms off the speedo and doesn't have repaired, rear passenger side damage
http://www.skylinesaustralia.com/forums/R3...le-t314425.html
cheers, its all standard internally :ermm:
284rwkw = 380hp
295rwkw = 395.6hp
I want to see when I set my electronic boost controller if I can have a few of these settings ie. high boost, mid boost, low boost :P
Adam
thats great mate your catching me up,it wasn't so long ago i was being called a liar for these sort of figures,keep it coming i need the competition to get me motivated to the next level
lol guess this website needs some updating? i'll be passing the 400hp mark in the next 6 weeks :)
http://www.skylineowners.com/forum/showthread.php?t=142304
are you doing the headgasket before you up the boost anymore,my tuner was concerned about taking it higher because of the standard gasket
200rwkw at 9psi
more to come if we can eliminate a lean spot when boost comes on at 3000rpm
breaks traction in any gear when you hit full boost, atmo vented external signals traction loss :s
planning to leave it at the current power level while I sort out the suspension, wheels, tires, and learn how to drive ...
Awesome work there Adam! Very nice set up, big turbo and still quite responsive judging by that graph, well done :ninja:
Cheers bud. Hows yours going at the moment?
nah, everyone thinks she'll be fine or atleast its not that worth it unless im taking the head off for other things.
200rwkw at 9psi
what wheels/tyres do you have currently? you shouldnt be able to break traction in any gear....
michelin pilot sports
standard r33 gts25t rims
only went to third gear, backed off after that ... so not any gear
found an electrical fault causing the lean spot, workshop thinks there is a voltage drop which is causing the fuel pump to drop pressure - resulting in the lean spot. hopefully we can track this down
  • 3 weeks later...
Finally got my R33 on the dyno, made 164kW at all four on 9psi.
Its an S1 R33 GTS4 RB25DE, stock R34 turbo, Stock R34 SMIC, Stock R33 GTST ECU + Injectors, Stock RB25DET exhaust manifold, stock R33 front + dump pipe, 2.5" cat back exhaust, 50/50 water+methanol injection.
Car was incredibly lean down low (14.7:1) for about 1500rpm IN BOOST, then stupidly rich up top (low 10:1) possibly in rich and retard mode, the tuner (Nick Summers) reccomends full aftermarket management (i was going to fit an SAFC shortly) so thats all a bit disapointing. Explains why i was getting detonation in low revs above 6psi though (the reason why i fitted water meth) and i do agree with the tuner.
Edited by SKiT_R31
nice, another 33 gts4 :thumbsup:
What did he tune as I thought theres not much to tune because everything is locked on stock ecu?
Also, what about afm? I changed that first thing aswell when I started on turboing.
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
