Here's my situation I've got my 32 witch has been t-boned has rb20det ( 264s, gtx3071 with r33 rear, power fc and all the mods to suit) 252kw (no torque )
I've also got a laurel with a rb25 de. I'm unsure if its worth putting all my parts from my rb20 stuff into the rb25de.
Any advice or help would be much appreciated
  • 1 month later...
What are peoples thoughts on using an rb20det ECU with nistune on a series 2 rb25de+t?
waste of time, just get a Z32 ECU (if you're adamant on using Nistune) if not get an old PowerFC for cheap
  • 3 months later...
Model - A31 cefiro
Engine - RB25DE series 1
Modifications / Parts Used - completely stock un open or modified block and head. garet turbo stainless top mount manifould, sard 650cc injectors, hdi intercooler kit,38mm wastgate
Engine Management Used - Link G4 plug in
Fuel Used - 95 octane and E30 ethanole
Boost Used - 8psi on petrol and 12psi on E30
Dyno Tune Results - 290hp on petrol and 360hp on E30
Misc- when preforming a de+t you have a reasonably strong base engine package to begin with. but the one problem you will always face is detonation due to your compression ratio puls your trying to force feed it more air. to combat this I used ethanol blend witch burns far cooler there for lowering your risk of detonation and the ability to run more boost= more power! I have used and abused this engine package for 3 years now with no issues to the (still) stock standard engine package. to this day I still recommend people to use a plus T engine overr a standard turbo engine
Costs - Parts: $4,000 Labour: $0.00 Tuning: $2,000
  • Like 1
  • 1 year later...
Hey guys im currently doing an RB25de NEO +T conversion for my R33 track car. I want to use a forward facing plenum but the intake ports on the head are smaller than the FFP ports. Anyone running a FFP on there RB25de NEO turbo engine? The plans are are a GT3076, ID2000 injectors, microtech, extenal gate on a modded 25det turbo manifold. I really dont want to use the factory 25DE inlet manifold.
Cheers guys
has anyone had any issues fitting a standard RB25det turbo manifold onto an RB25de NEO? Looks as if i need to die grind the holes in the manifold where it bolts up to the studs. Have tried 2 different standard 25 turbo manifolds and same thing on both. Not a big problem, just wondering if anyone has had the same thing happen
Cheers guys
wrong thread man...... now its all spammed up ...
booooooo
anyway ask questions here --> http://www.sau.com.au/forums/topic/33407-how-to-turbo-your-na/page-42
now someone make me into a mod....muhahaha SAU domination :verymad:
  • 3 months later...
  • 2 months later...
MODEL: R32 gts
ENGINE: RB20DE
Mods/ parts: R32 gts ecu and injectors.
EBay intercooler kit. S1 rb25 turbo. Pod filter.
BOOST: 12PSI
FUEL: mostly 98 unleaded.
Standard 92 in country tassie when times are tough lot.
Power: don't know but beats modified V8 commodores and wrx's at powercruise.
Other notes: have now done 30,000kms thrashing the fu#k out of the old girl. Held back on posting a review for a couple of years because I don't want to give bad advice to people.
It's now been tested and all I can say is that a turbo setup on a Na with a standard turbo ecu with turbo injectors has the same reliability as a standard turbo engine.
Will try to get to a dyno soon.
cost: approx. $1000
(turbo,manifold, water and oil lines) $400
(ecu and injectors) $200
(exhaust downpipe, custom intake) $300
(other sh#t) $100
  • 1 month later...
  • 3 years later...
Greetings friends.
I am new to the topic but I see that you master it very well. I have 2 rb20 one aspirated and another turbo, I would like to know if it would be better to invest the money to the aspirate to get more profit or simply mix them.
Anyway, I've been thinking about doing the rb20 of + t but I would like to hear your opinion and recommendations.
Thank you.
6 minutes ago, Pedro_rosario said:
Greetings friends.
Thank you.
Have you got two cars or just two engines? If the latter do up the turbo engine and drop it in. You will still need the ecu and loom and an intercooler of course.
  • Like 1
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
