is pumping the stock turbo up to 10psi a bit or a risk? as far as i am aware, 10psi is the absolute max you can push the turbo to (correct me if I am wrong) and i would not want to be driving with a turbo that is stretched to its limits.
Hearsay and conjecture.
Depends on which stock turbo..
25s2 and neo turbos have the nylon compressor wheel which likes to delaminate when leaned on too much.
rb20 turbos, mine took a beating on 14psi for about 6 months before I sold it
25s1 turbos (with steel compressor wheel), mine was on the RB20 @ 12psi for a year and has been on the RB30 @ 12psi for a year aswell. On the 30 it's choking up something chronic (which means it creates excessive heat too) and it still hasn't shat its' exhaust wheel..
hey
i got a manual boost controller but im not sure how to set it. can someone set it for me[was told i need a boost gauge to set it properly] only want it running 10psi
thanks Sunny
sunny i have a spare boost gauge you can borrow if you want
set it all the way down, then 4 clicks up... thats where mine is set, n im running just under 10
which part of 'no clicks' did you not understand?
and 1 turn != 1 psi, get a boost gauge and find out exactly what it is doing, otherwise you might be hunting for an exhaust wheel in your cat.
my RB25 turbo was on 13psi for the 3 years i had the car, plus however long before i bought it, and only gave up when the engine threw a leg out a bed, and presumably crap though the turbo.
Guys guys guys.
NOT ALL RB STOCK TURBOS ARE THE SAME.
RB25 seriesII and RB25Neos can't handle as much boost as the RB20 and RB25 seriesI turbos.
I really wouldn't be pushing a nylon compressor wheeled turbo past 10-12psi.
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
    • He means "as opposed to mechanical cable drive". Older cars (R32 for ex.) had cable drive. Later cars with essentially the same gearbox, ie R34 GT (NA RB25) used essentially the same box as the R32 GTSt, but instead of a cable drive, had an electronic speed sender plugged into the same hole in the box, running from the same little gear that would have run the cable. Some of the shittier later cars use a speed sender on the nose of the diff, or the ABS sensors.
    • Lower than engine, or lower than it should at the hubs? Either way, that is a nice power figure and I'm not surprised you say it rips now. What stopped you from turning it up any more? Injectors? Or did it just stop responding to boost?
    • Got my 34 gtt tuned last week. Car made 362 wheel horsepower at 19 psi. Turbo was the ATR43SS. Only other upgrades were haltech 2000 series. 650cc injectors, walbro 250, fmic. Pro hub dyno reads 6% lower than actual figure according to my tuner. Car is a real ripper now.  IMG_7261.mov
    • Hi everyone, I'm wondering if anyone in Melbourne (preferably West) has a non-S2 R34 front bar. If it's already off the car, even better!  Nothing too weird, I just need to get a cut-out of the hole that the front indicators clip into 🤣 (image attached for reference)   I've got a front bar from JSAI Aero, but those holes need to be cut myself, and I want to get it right so the indicators will clip securely. And my OEM bumper is a S2, so I have no reference. So looking for a member who might be able to spare me a few minutes to make a cardboard cut-out using your front bar.
