As topic states I am in urgent need of an auto sparky in the Osborne Park area!
Basically my GTR is having a fueling issue so I need someone to diagnose problem so we can chuck in a new pump or relay etc to get her going!
I am working away at the moment and have been waiting on auto sparkys now for 2 weeks and have yet to have one come down and have a look and diagnose the problem!
The car is about to be put onto a transport truck and I need the car running by first thing next week, all i need is someone to go diagnose the problem the rest we can take care of?
If anyone knows of someone in the area or someone who may be able to help, I am more then prepared to pay for or supply carton etc!
Thanks,
Dan
What is the exact problem?? I may be able to tell you hw to fix it with more info. Is anything else affected as well or just the fuel system??
Not exactly sure of problem as I havn't been down there myself to look at but from what my panel beater has said: all electrics fine, pump is making an unusual noise - intake removed and no fuel being fired so presuming its fuel pump/relay end?
Is there anyway of testing relay/pump?
Are the relays vehicle specific?
Just talked to my Panel beater and he has told me that is the Relay making a funny noise (TICKING NOISE) and he has checked the fuel line and there is no fuel being fed?
So Maybe not the pump?
Where can I get myself a relay from?
Thanks,
Dan
Do what i said first.
Relay's are supposed to tick when they enguage, and tick when they release. They can be bought from many places. Nissan would be a start.
Thanks mate I will call my panel beater and get him to give that a go! Yeh I know relays tick when they release and engage but if its a continuous clicking of which it sounds like (from what the panel beater has told me) it could be turn itself on off on off!
Sounds like either:
A: Bad signal from ecu to relay or
B: Bad ground to relay
A relay should only click once for on then once for off as previously stated. If its contiuious then it will be one of the above. From memorie the ground is on the other side of the boot latch to the fuel pump relay.
I go past O/P on the way home i can drop in for you and have a look, also those relays are hard and expensive to get from nissan however i think i have a few spare at home.
Cheers
Ross
Sounds like either:
Cheers
Ross
The sad thing is that a relay is a relay. It would be pretty easy to hook up a cheap relay to do the same job.
EDIT:
Thinking about what you said, its probably just a bad connection somewhere and the relay is more then likely fine.
Edited by Tezzah
Sounds like either:
Cheers
Ross
Hey mate would really appreciate that, I have talked to my panelbeater again in he is of down at kyp getting some other bits and pieces and is seeing if he can get a relay off of them!
Apparently the relay was clicking for about min+ and then stop etc so it sounds as if your write on the mark with a grounding issue!
The actual rear quarter panels and rear wheel arches were removed and new ones put in there place i wonder if it has in someway affected grounding of the relay etc!
Have sent PM to thanks!
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
