Bagged ** Shaved ** Wagon
Item:
2000 vt aclaim wagon
coffs harbour 2450
Website: this one
Item Condition: clean
Reason for Selling:
want to go faster
Price and Payment Conditions:
swaps for r34 plus cash adjustment
Extra Info:
* shaved doors, blinkers, antenna, petrol filler, rear windscreen wipper, badges removed
* f.b.s.s air bags 3/8 lines
* playstation cotroler for air bags
* 185 ***kms
* 19" valuts 90% tread on all
* alpine type r speakers and tweaters
* 11 months rego
* personalised platers
* all engineered with papers
* pacemaker extractors and a V8 5.7l exhaust system
* playstation control switch board for airbags
Item:
coffs harbour 2450
Website: this one
Reason for Selling:
want another 2 stroke.
swap for moto or extra cab hilux... have to put a price so $14,000
Extra Info:
* 183 ***kms
* 11 months rego
Pictures:
http://i78.photobucket.com/albums/j99/chee...rlenscar006.jpg
http://i78.photobucket.com/albums/j99/cheeppimp/DSC00776.jpg
http://i78.photobucket.com/albums/j99/cheeppimp/IMG_0148.jpg
http://i78.photobucket.com/albums/j99/cheeppimp/103_0129.jpg
http://i78.photobucket.com/albums/j99/cheeppimp/103_0122.jpg
http://i78.photobucket.com/albums/j99/cheeppimp/103_0123.jpg
http://i78.photobucket.com/albums/j99/cheeppimp/103_0124.jpg
http://i78.photobucket.com/albums/j99/cheeppimp/103_0126.jpg
http://i78.photobucket.com/albums/j99/cheeppimp/103_0120.jpg
http://i78.photobucket.com/albums/j99/cheeppimp/103_0121.jpg
message me and ill get back to you after 5pm 0412861794
cheers
 Share
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
