He was pulled over by the Police in Marion St Leichhardt.
He's been pulled over before in his highly modified donk Alfa 33 and got pinged.
Plan B:-
He keeps both of his 'Remotes #1 & #2' on him at all times when in this car.
He keeps them separated from his keys.
When he's been pulled over this time, he got out of his car and locked it with #1.
The officer asked him to pop his bonnet, he said, "Sure Officer" and pulled out #2.
But #2 didn't work. Then he presses it again in front of the officer and nothing happens. He said, "I'll have to go back home and get the other one then."
He got let off.
There was one flaw that the officer didn't pick up on, but that didn't matter.
Comments?
https://www.sau.com.au/forums/topic/249207-preventing-defect-detection/
This is the most laughable strategy I've heard for a while, even more so that a 'lawyer' came up with it.
Will not work:
* I'm pretty sure its defectable to not have proper 'control' of your vehicle, much like the 'broken bonnet latch' trick
* By going home you will need to leave the car where you stopped it, hope its not on a highway / no-parking / no-stopping zone
* Chances are the cop will call in a tow-truck to move it if point 2 is true, chances are it'll be moved to an impound yard.
Yeah some lawyer this guy is...
Very good, but obviously the officer didn't twig that he still must have the keys to drive the car and the same keys will also open the doors.
Would be noisy but meh.
Am I correct, do I win with my simple non random non rant (answer)?
Edited by madbung
not a bad ploy me thinks. alarm would go off but depending on the alarm it would turn itself off after a while. door would still open and you would still be made to open the bonet. maybe say your alarms playing up and whenever the coppa puts his head under the bonet turn your alarm siren on to make it uncomfortable on his ears and hope he doesnt take to it with his gun.
Cops don't use their guns in australia, what are you on about......It's not like the car is holding two knives or something ;)
Two points to make.
If you think it will stop the defect, it wont. You will merely be directed to an inspection station.
You commit an offence by obstructing the officer. The lawyer risks being removed from practice if it became common knowledge that he knowingly assisted in the commission of an offence.
Not a real smart lawyer.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
