  • Replies 115
Originally posted by R33 GIRLY
lol, how much dosh do i need tosh? (ok was silly joke but had to get it out)
$20 per night
guess some of you need to be half tanked before the social get-together or will be a stare off
:bahaha: :bahaha:
um yeah, i will be the one at the show wearing the little top....
GEZZ! You will REALLY stand out wearing a "little" top at Sydney Auto Salon.
Hell last final battle there were two lesbians pashing off on the stage in tiny nurses outfits! (I have photos to prove) :P
I may just have to come along for the ride on this one... will see what is doing closer to the event...
But I did get lost back there, I got the bit about a $5K bar tab, at B-mans house, near the beach, on the floor that R33 GIRLY books out with all her blond friends, that benm has volunteered to be the bouncer and fatz is going to attend... but where is B-mans house?
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
