  • Replies 55
Just can't help reading this thread over and over again. Making 260rwkws at 5000RPM on a CA this is just insane. Even SR20s on GT2871Rs can't even do that as in both response and power. really good work guys can't wait to see what can it do on my RB25.
ask and ye shall recieve :laugh:
URAS - how much are the cams in the CA helping with this figure?
The more I read about CA's the more I want to try one as the next car.
I'm curious to know if this $900 ATR28 turbo is available as a bolt on to an RB20 and if so, what would it make.
They are cheap re-grinded cams: 256/8.9 . I got done 3 years ago at wade which costed me $120 in total for 2x. I guess they didn't even know what a CA18 is back then. You can use Tomei Pon cams which will give better result.
ATR28 G3 will be available next year as in a direct bolt on form we are doing our modeling at moment. This CHAR is highflowable into Stock R3x Turbine housing. by calculation it should give similar result with lot faster response. We will make one for evaluation and should have the results by new year. But drop in an email if you are interested in evaluation.
Edited by hypergear
S15 with GT2871R 56t (stock bootom end)
vs CA18det with hypergear turbo.
good comparison. the CA makes a fair bit more power but the SR would definitely be punchier on the street. at 3500rpm the SR has 110kw vs 60 for the CA. and at 4000rpm it's 165kw vs 100kw. but at 5,000rpm you've got the SR with 220kw vs 260kw for the CA. so the CA would be a fairly exciting ride from 4,000 to 5,000 since it more than doubles it's power in 1,000rpm! fair bit of wheelspin in 1st and 2nd i'm guessing. :P it's still a kick ass budget set-up. now trent, try the same turbo, on an SR with built bottom end and some cams. should make the same if not more power and a bit more response too.
Rich, in my experience the trick is to never let the needle of the tacho get below 5000rpm. Problem solved. CA18DET FTMFW!
I want one of these engines in a little Datto ute so bad.
Yea the CA's gear ratio is different from the SR. If you’ve driven one you know, It needs 3000rpm just to keep the car moving but revs out very quickly. From daily driving the car operates from 3000 to 5000RPM, even compare to stock T25 turbo there isn't really any thing till after 3500rpm.
From actually driving it, it doesn’t feel any lag at all, pretty much just like factory turbo. But when you step it in. ha ha ha ha fun begins, wheel spin on 1st, 2nd and 3rd at 100KM/H jumping from 80km/H to 130KM/H in 2 secs grab on to your steering wheel , hear the loud whisper from the turbo and let your body sank into the seat
On SR probably get abit more power but should see heaps better turbo response and more torque.
Edited by hypergear
Pretty much like the factory turbo? Right......
Looks good at 18psi, but the higher boost level curves start looking poor. Compressor is probably beginning to run out of flow.
Edited by Equinox
try 23 psi :) the increase from 18 to 23psi yeilds great results, yet from 23-25 it definately hit the wall. i agree it doesnt drive much like the stock turbo but who would want that :P
yea, the turbo got more responsive, It must've run in, It had 300kms before the tune. Also I found and fixed that electrical issue, it was in the bit of loom our friend made, Its running beautifully now. I’ll see you next week to dyno the new KAI turbo.
try 23 psi :cheers: the increase from 18 to 23psi yeilds great results, yet from 23-25 it definately hit the wall. i agree it doesnt drive much like the stock turbo but who would want that :P
Ah yeah. It does look quite good through the over few runs in the middle.
It must have 'run in'? Doesn't quite work like that. Surprised a turbo 'manufacturer' would be under the impression that plain bearing turbos take a few thousand kilometers to 'run in.'
Edited by Equinox
Ill be in for one of these, once the t3 housings are sorted, or possibly the atr43i, can anyone shed some light on what the specs will be?
my hi-flow is dieing and didn't make anywhere near the power it should have :P
LoL never you heard turbo run in? all brand new bush bearing turbos will need a run in time of 1000KMs. Boost curve will change once its run in. eg:
before run in:
After run in:
Its good to see some guys finally giving the mighty CA a wrap...id love to build a tough one of these.
I think with the right headwork i could get it to match that SR down low.
Someone surely wants one built....2rismo...go and buy one.
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
