  • Replies 55
  • 5 weeks later...
Some more interesting Results. I found this on NS. which I believe the torque is abit funny. Its a GT2871R on a worked SR20det with Greddy cams made 280rwkws (highest GT2871R results I ever seen). This would be a back to back comparison of ATR28 CA18 VS GT2871R SR20
GT2871R SR20det 280rwkws Original Dyno sheet:
I spoted above power curve into ATR28 CA's dyno sheet:
Edited by kwickr33
I know this has been mentioned a couple of times but what about a series II skyline turbo highflowed from hypergear? what do you guys reckon? i might do it, but the thing is its hard for me to take off the turbo... mayb alot of wd40 might help.. :)
be good to see how the sr20 would go with the atr28, should be as responsive as the 2871 but make a healthier power curve
I've never seen GT2871R making 280rwkws before. ATR28G3 on the same car same dyno should make around 320rwkws.
the operator has just printed the wrong torque graph, he has printed tractive effort not actual torque.
as for 280rwkw out of a GT2871R..... there is no way i can think of to crack that power without E85.
Edited by URAS
87.6mm stroker cranks due around April :-)
Its good to see some guys finally giving the mighty CA a wrap...id love to build a tough one of these.
I think with the right headwork i could get it to match that SR down low.
Someone surely wants one built....2rismo...go and buy one.
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
