Stock R33 Parts For Sale
Hey guys I am currently in the process of giving my stock series 1 r33 a little more power. I have some stock parts up for sale if anyone is interested give me a pm. Car is a 5 speed manual turbo. I am negotiable on prices i want the stuff gone. Do have pictures for every item just yet but I can get them on request. I have two houses and currently the car is at my house in Townsville until I get it back down to the Whitsundays to finish the rebuild.
Parts Include:
Stock cooler: $60
Stock Fuel pump: $50
Stock injectors in rail (with loom): $100
Stock ECU: $150
Top Secret tuned ECU**(more info on ECU below)**: $500
Stock boost control solenoid: $20
Stock AFM/MAF sensor (broken): $20
Stock manifold: $80
Stock turbo (with elbow): $500
Stock intake plenum: $60
Stock air box: $60
Stock coil packs: $100
Stock exhaust cam gear: $50
Stock BOV with crossover pipe: $60
Stock throttle body: $50
**More Top Secret ECU info**
ECU has been retuned by Top Secret and is a perfect upgrade for cars with basic modifications. ECU has been retuned for FMIC, stock injectors, stock turbo, electronic boost controller, pod filter and exhaust. ECU has rev limiter raised to 7500rpm and the speed limiter has been cut. Fuel air mapping has been retuned for all the way up to 15psi so you can up the boost and not worry about running your motor too lean. It has been a great ECU I'm only selling it because I have gotten larger injectors and turbo and I'm now running a Power FC.
Contact me via PM or email me [email protected]
;) Cheers :(
Edited by Lukas 33
I just remembered I also have a couple more parts up for sale.
Stock silicone intake pipe: $50
Stock cam breather and BOV recirculation pipe (leading into silicone inlet): $20
NOTE: I am more than willing to trade for other parts. I will trade everything in this list for some forged pistons and ARP head studs :bunny: Like I said I am open to trade. Im after braided oil and water lines for my turbo if anyone would like to trade. Cheers :bunny:
Updates:
Stock cooler: $60
Stock injectors in rail: SOLD
Stock injector look/wires: $50
Stock ECU: $150
Top Secret tuned ECU: $500
Stock boost control solenoid: SOLD
Stock AFM/MAF sensor (broken): SOLD
Stock manifold: $80
Stock turbo (with elbow and actuator): $400
Stock intake plenum: SOLD
Stock intake runners: $50
Stock air box: $60
Stock crossover pipe: SOLD
Stock blow off valve (BOV): $50
Stock bov return and cam breather to intake pipe: $20
Edited by Lukas 33
  • 11 months later...
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
