Anyway 2day was supposed to be the day i got my car dynoed with with my brand new power fc. My mechanic instaled the power fc and aparently theres a fault with it. He cant get the engine light to go off. Im pissed off because im going away to tassie for 2 weeks at the end of the year and i would of liked a bit more power to go with.
Edited by sturb25
https://www.sau.com.au/forums/topic/249260-brand-new-faulty-power-fc/
Damn man thats a shocker... my power FC has the check engine light flashing when the car is in accessory mode, goes off when ignition is on tho so it doesn't worry me ;) hahaha
Did you buy the unit new so can get a replacement??
the engine check light is lit due to pin51 NOT getting about 3.7v
Pin51 is the traction control which is present on R34 GT-t's but not on S2 RS4S.
the engine can be tuned and run perfectly without setting up the correct voltage but you won't see the light flash if you have excessive knock or other engine checklight situations.
it is a small wiring job to get this light off. the answer of the correct voltage was supplied by EGA4IT.
it can be tuned quite happily if you want the power and it should run the car normally otherwise.
Edited by wolverine
Didnt work mate. could not get rid of the engine light. Going to take it to a Auto Elec while im down in tassie
Yeah i printed out about 20 pages on it and gave it to my mechanic and he reckons he tried the method suggested on page 1 and it didnt work. So he said he didnt want to try any more incase he stuffed my computer up which was fair enough. So im going to take it to a auto elect too see what they can do. Will let u know what i come up with. Thanks
that's a pain.
did you turn boost control off on the powerfc. default setting is on and if there is no apexi boost control that will throw up the check light as well. this is well known so i am presuming the mech switched this to off already.
if you have a commander go to sensor check and have a look there. check the boost control is set to off here too.
the powerfc faq that paulr33 has set up should help you do some trouble shooting from your end too.
    • Once the belt slips it can very easily cause a cascade that encourages more belt slip. Check the pulleys carefully and see if the grooves have cupped. If it has it's time to replace the pulleys. If the rubber has glazed you also need to replace it. Shouldn't be shiny. From the factory there's a lot of exposed fibers(?) on a v-belt that will go away as it's broken in but some should still remain visible without sticking out significantly like a new belt. I went through this on my dad's Camry recently. It would keep slipping even after setting the tension higher, only solution was a new belt.
    • Belt polished and/or pulley(s) glazed. Rub pulleys with sandpaper, replace belt.
    • I've also got a quick jack. I would never get under my car again without using it.  While it might be quicker to use a jack and stands, it is such a quality of life improvement that I wouldn't have it any other way now.  How much slower the quick jack is to setup will be based on your circumstances. Can you leave the jack rails on each side of the garage? Can you leave the hydraulic lines attached? etc.  If you can drive the car into the garage and simply push the jacking rail thingos under the car into place, it is super quick to setup and use. But if you have to pull the pump unit out of storage, attach the hydraulic lines, wheel out the lifting rail thingos.... yeah takes a bit of time. Having said that, I would still prefer that to using a jack and stands lol.
    • Sydney Tools have them for ~$3400. More than the Quick Lifts but these seem better. https://sydneytools.com.au/product/quickjack-7000tl208240v-5175642-7000lb-110220v-portable-light-duty-truck-and-passenger-car-lift-system
