you must understand also the associated time, overheads, risk, etc that has to be factored into dyno time. Anthony is charging $400 for a tune which in my opinion is way too cheap. Does QT do the timing map? or just the AFR's?
Yeah but thats to tune a power fc, I have done a complete Power FC remap in r33's which have had bigger injectors in less then a hour, have done sooo many of them I can get them knocked over in no time at all
new firmware is available. 4.2.3
ohhhhh santa has come early this year!!! I will be uploading that this weekend
  • Replies 155
ECU Firmware Release Notes
IMPORTANT
Please read this document carefully. It outlines new features and fixes for all released ECU Firmware versions. Make sure you understand these changes and take the necessary steps to check and initialise all new features.
After reading this document, close this window to continue with the firmware upgrade.
NOTE: DO NOT attempt a Firmware Upgrade within one day of a race meeting. Adequate time should be allowed to solve any problems that may arise.
ECU Firmware Updates and Fixes
WARNING: Once an ECU has been upgraded to V4.3.2 there is no going back to a previous version. Be sure to allow adequate time to set up new features and solve any problems that may arise.
Firmware Version 4.3.2– 1/12/08
Fixes
Rotary Trailing Ignition. With the Ignition selected to "Rotary - Leading Wasted" only the front trailing matched the split table. The rear trailing split always lagged 12 degrees behind.
Firmware Version 4.3.1– 26/11/08
New Features
Suzuki Swift VVTi trigger decoding added.
Firmware Version 4.3.0– 20/11/08
New Features
ECU on-board datalogging. Number of logged parameters is fixed with adjustable logging rate and activation method.
Wide Band Closed Loop Lambda using AFR Target Table.
Audi 5 Cylinder 135 tooth trigger decoding.
Key-On Speedo sweep function.
Baud Rate adjustable. 115200, 57600.
Password Protection.
Fixes
NB Closed Loop.
Temperature channels other than ECT and IAT showing incorrect values when in a fault state.
Ford BA XR6 Turbo Cam control.
Changes
You can now select the number of active Fuel Drives when Staged Group Injection selected.
Hey guys,
what are these vipec ecu's like compared to something like fcon pro? put the limitations aside with the fcon's "access to tuning software problem" and tell me what you think!
tho i guess this question would be hard to answer since not many people have looked at the fcon from a tuning point of view but surely someone would know :banana:
Cheers.
i will probably give the firmware a go this weekend also.
That frees up the narrow band analog input for your EGT sensor/s too Anthony.
yeah or my gizzmo k-mon :banana:
my car is now running the new firmware, the wideband closed loop is working though needs the fuel map to be much more accurate than the narrow band closed loop does or it is a bit slow to pull the AFR up (or i need to fiddle with the gain control more as i am currently using the same value for WB as i was on the narrow band)
nice... I aint game to upgrade firmware till i get to newcastle :blush:
Im running this ECU in my GTR and am extremely happy with its performance its definalty on par with the Haltech E11v2 i was using before. Just curious how much did the external map sensor cost? as im thinking of boosting my car abit more.
yay another line running vipec.i have had mine insalled for about 10/12 weeks and its been great.
Boost settings never give me any rob compared to my old ebc or manual boost controller
wont be long and i will be wanting another one in my HR30 running L20et
Its a rebranded Link computer by all accounts. Link of late have lifted their game substantially and make some pretty sharp ECU's.
I remember actually posting something suggesting re the new Link Ecu's in the tech forum a few months ago and being rubbished about the specs vs power fc etc. Its quite funny what a name change can achieve.
Glad your happy with your ecu mate. The one running in my car I cant fault as yet.
The plug-in boards are a TF electronics product, marketed and sold by Ray Hall (Vi-PEC) but yes they use the same chipset and tuning software as Link. The development of this product without TF's input would have seen the Link product not be at the standard it is today as TF did all the development on it. In effect the Link ecu is a re-branded Vi-PEC product, thats the reason why "link have lifted their game" as you put it. If it wasn't for TF's involvement the Link product would still be sub-standard.
has new firmware been removed from website ?
Titan, can you email it to me? [email protected]
Or was it removed for a reason? or am i missing something?
Hi Paul
It doesn't do timing, just AFRs.
I do understand your point re dyno time. I'm also trying to be as objective as possible, and not being critical in the least about either Vipec or the tuners who use it. However, if the product's own website, and the man who developed it, state that a full new new map can be done in 20min, and better than most tuners, then the tuning time and cost should be less than for a product that doesn't have the same functionality. I've always thought that's why people pay for functionality in a good product like Vipec in the first place.
If the cost of tuning doesn't change because despite the advantage of QT more time is required to utilise the extra features offered by the Vipec that would be understandable, but this is almost the opposite.
It's up to individuals what they do, but I'd welcome any logical explanation as to why a time saving function that the owner pays for shouldn't lower the cost of fuel mapping. Anyway...just my 2c, this thread is about Anthony's experiences.
Cheers
Trent, i soldered the Vi-PEC loom to one of Rays adapter boards so the V88 unit just plugs in....easy!
who are these available thru? ray or someone else?
Edited by Cartman
to be honest every product needs a gimmic to market (the autotune is no gimmic) and with the vipec they have chosen to that particular feature to spruke. I come from a marketing background (of late).
Auto tune is great but there is also the time needed to actually interface the wide band etc... which itself probaly takes more than 20mins the first time you hook it up.....
To me i pay for a product like the vipec as it has the resolution and computing power upgradabilty add on features etc... all thing required to do the job properly, to me the auto tune side of things is a add-on luxury that makes no real differrence to the ACTUAL ecu... what if microtech offerred the same autotune? i know i still would not buy one.... buy an ecu based on other parameters... of which the VIPEC / LINK has loads.
Edited by URAS
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
    • To re-cap, I bought: https://www.alibaba.com/product-detail/Lsailt-8G-Infiniti-Q50-Q60-2014_1601171829627.html?spm=a2756.trade-list-buyer.0.0.2cd476e9FTIlKE As you can see, if I bought 20 it was $653, but I bought 1 so it was $1,170. I was very tempted to buy 2 and resell 1 at 25% cheaper. @MBS206, I am not sure if they do a Kluger one, here is their list but it might be there under a global model name: http://www.lsailt.com/product/android-interface?page=1 Keep in mind these full android replacements have basically all the bits a phone does (cpu, ram, storage, wifi, bluetooth, usb interfaces) other than a screen (it uses a host), thus the $800+ cost. Android Auto screen mirroring is MUCH cheaper as it's just a cut down shell, input mirroring and output mirroring BTW I also need that "screen off" feature, it is much harder to see wildlife even if a dash is reasonably dark. Both the Fuga and V37 have display off buttons for night use, they just come back on for a second or 3 if you interact with it, eg skip a song.
    • I use FCC car launcher. It has an option for different backgrounds, so instead of turning the screen off you can swipe 'up' to a black screen with no background/icons. (mine has the time on it only). It's kinda nice. Also lets you use gestures to say swipe to go to next song, etc.
