just picked up my vi-pec plug in board and a boost controller solenoid.
if you go with the vi-pec solenoids you'll need to get some 1/8th BSP hose end fittings from somewhere like autobarn or auto-pro etc.
what i noticed was the solenoids looked very similiar to my profec b spec 2 solenoids, i asked scott from insight motorsports about this and he said that you could use a profec solenoid as it is pretty much the same thing, you just need to cut the loom off and wire it in.
  • Replies 155
Id be interested to see whether anyone has bothered to run the boost controller that comes with these computers. The guy whos retuning my car was part of the development team of these new ecu's and said they are incredibly good.
Wouldnt mind hearing some other opinions as naturally he is a tad bias!
Cheers
i am running the boost controller built into the board through the stock GTR solenoid and it works perfectly
well at least it was til i blew big end bearing and pulled car off road to rebuild
Ray seems to think its possible so I'm going with the stock GTR solenoid.
Taken from the help file with the vipec software.
The number and spacing of the cells in the Table is completely user adjustable. Rows/columns may be inserted or removed where desired by right clicking in the desired place on the labels of the RPM Axis or Load Axis (ie right click on the RPM values to insert a new RPM column). This flexibility allows fine spacing in areas where high resolution/accuracy is required and coarse spacing in less critical areas. The maximum number of RPM columns is 22, while the maximum number of Load rows is 20. When adding a new row or column, the new row/columns cell values will be interpolated between the values in the rows/columns which it was inserted between.
440 maximum load points in each map
And Autronic has 18load, 32rpm. Does that sound correct?
So 576 to 440 points
Yep, but you must have a LOT of time on your hands if you intend to try and tune all of those cells...
The interpolation works very well on both ECU's so you dont need anywhere near that amount of cells in reality if you're only using a revlimit around the 8000rpm region.
I own both an Autronic SM4 and a Vipec V88 and I'm not using the full resolution on either ECU.
Edited by CHA54
Roger that, I agree. I guess for an engine running to 15,000 rpm the extra points may be more useful.
The reason I ask is I was very close to purchasing an SM4 @ $2100(trade price) but really like the idea of a plugin ecu, especially in the std casing. As far a I can tell, all I need is a knock amp to gain all the features I could possiblely need for my motor.
Is there any other functions apart from increased resolution that the autronic has over the Vi-Pec? or visa versa?
Is the cost of the RB26 plugin $1650? or more expensive since it has a built-in MAP sensor?
I am the same, i have a autronic in another car and its awesome, i want to try the vipec but i HATE being burnt by new products, seem to stick with the known good now.
but it seems good and im getting OVER pfc missfire.
Edited by GTR1993
Just went up...they are now $1760 inc gst.
yeah but its nice to condense the resolution near peak boost torque areas or where fast increase in boost and rpm occur to get a nice fuel and ign curve etc. Nothing worse than having big steps and relying on interpolation on big hp cars.
Had a tubbed pro street car making 700rwhp in last week with a "?????" ecu and the resolution was a real issue.... lazy high nine 1/4's on street rubber but i know it could make more power, run quicker, be more driveable (as its a pro street car) and use far less fuel with a different ecu.
Edited by URAS
Just got a quote yesturday for $1663 inc +$20 to upgrade to a 5bars MAP and $280 for a knock amp
must be old stock as all new stock ordered after the 1/2/09 is under the new pricing.
grab it while its cheap!
    • Hey all, a little help from the Stagea hive mind plz.. I'm days away from buying either a 2002 Stagea 250tRS AR-X Four, premium leather, power seats and all the old switches etc that go with it, or a 2002 Stagea 250tRS VR-X Four AERO, pov pack, cloth seats etc, with coil overs, sports zorst, comes with original zorst and suspension and parts. (I think I've got the models right?) Both are VQ25DET, have 160000kms, both straight no rust both with $2000+ in recent servicing receipts, both ride on aftermarket 18" rims. The Aero has a replaced turbo as well. I like the cool factor of the Aero car but the AR-X has never been modified. Neither have been driven hardly at all in the last 5 years. Any thoughts on which one or does it come down to personal preference? davemoto
    • Please let me know if anyone has seen my black Nissan Skyline 350GT-8 taken from Robe Terrace, Medindie, SA suspect taken between end of March to early April 2025! Have called impound yards & tow truck operators, no where to be found while I was away overseas! Plates DXPRS1 custom dark green on yellow back. Has a rear lip boot spoiler on the back as well.
    • A few interesting adventures it seems...
    • Hey new to forum and about to pull the trigger on a Stagea.. I'll post up some pics and questions (I have many..) in another thread. Hope to hear from 4 door wagon owners for advice.. dave moto63
    • It'll only be as clunky as you are with the clutch pedal...
